-   -   Things that make you go "DAMN IT".... (http://forums.pelicanparts.com/porsche-911-technical-forum/749100-things-make-you-go-damn.html)
Devil Dog Mosport 05-09-2013 02:59 PM
Installed the headers, extensions and Dansk sport muffler..took some tweaking , got the bumper back on and then looked over in the corner and saw the rear engine tin..... DAMN IT!!
Easier to take the engine brace off (all solid mounts) than removing the exhaust again... Think I can squeeze it in this way???
James Brown 05-09-2013 03:39 PM
damn it that sucks
ddinham 05-09-2013 04:43 PM
Damn it!
http://forums.pelicanparts.com/uploa...1368142995.jpg
72T 05-09-2013 04:58 PM
Moments like that can make you feel like your whole world is turned upside down...
sobamaflyer 05-09-2013 05:00 PM
Reinstall your just rebuilt engine (by yourself), runs, woo hoo! Forgot to align the clutch fork with the pilot bearing so the motor needs to come half way out again.....DAMMIT!
quattrorunner 05-09-2013 05:14 PM
haha.
My dammit moments are using the apple phone and submiting sideways or upsidedown pics. Happens all the time.
quattrorunner 05-09-2013 05:15 PM
I did that too. Dammit
ddinham 05-09-2013 05:33 PM
Weird? On the IPad it appears rightsideup.
James Brown 05-09-2013 06:29 PM
thinking the tone ring on a 3.2 flywheel is the starter ring, DAMN IT! (not me but many)
rw7810 05-11-2013 07:16 PM
Putting the brake calipers on the wrong side and unable to bleed the brakes - DAMN IT!
Joe Bob 05-11-2013 07:33 PM
Nipples up.....like wimmen.....
schumicat 05-11-2013 08:02 PM
install drivetrain with "new" trans in SC, go to hook up clutch helper spring...notice that trans is set up for clutch mechanism without helper spring and shaft has no place to put the spring...must drop drivetrain and separate engine/trans to install new style longer shaft.
Ronnie's.930 05-11-2013 08:36 PM
ddinham is another one of those "types" that likes to hang his vehicle from the ceiling when working on it (and hangs the other garage stuff from there too)! Did you get some tips from quattrorunner? If not, ask him what he uses to stick his car up there! :p
rinverso 05-11-2013 08:51 PM
walk into the garage to take my baby for a ride.......and dead as a door knob. guess i'll be checking the alternator replacement guide thread. crap:mad:
quattrorunner 05-11-2013 09:03 PM
ddinham is another one of those "types" that likes to hang his vehicle from the ceiling when working on it (and hangs the other garage stuff from there too)! Did you get some tips from quattrorunner? If not, ask him what he uses to stick his car up there! <img src="http://forums.pelicanparts.com/ultimate/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg">
Omg that's just too much dammit. Funny though:)
crownarch 05-11-2013 10:11 PM
At 70 years of age, if I take out more than two bolts I will forget where I laid them. Dammit!!
dtw 05-12-2013 12:56 AM
Install 4-piston aluminum Brembos on my 928 and spend hours bleeding them. Get frustrated, check the factory shop manual.
-bleed master cylinder- check (wish my 911 master cylinder had a bleed nipple)
-bleed clutch slave- check
-bleed BOTH bleed nipples on each caliper- DAMNIT
mr911er 05-12-2013 03:41 AM
I do that and I'm 50
gamin 05-12-2013 05:46 AM
Instances too numerous to list. Latest yesterday. Changing trans oil on 70. Just started pumping first quart. Wait, there's a leak. No, forgot to reinstall drain plug. DAMMIT.
hcoles 05-12-2013 08:21 AM
I have the same problem, put a screw driver down on a work bench, go to grab it 1 minute later and can't see it, AND I'M LOOKING RIGHT AT IT
