-   -   Odometers quit but Speedometer works (http://forums.pelicanparts.com/porsche-911-technical-forum/749416-odometers-quit-but-speedometer-works.html)
autobonrun 05-11-2013 05:40 PM
The odometers on my 1979SC with 213,500 miles suddenly quit. Both the main odometer and reset odometer stopped. The speedometer reading still works fine. I assume both work off the same cable so I'm thinking that this means the cable and cable connectors are fine and the problem is within the speedometer unit itself? I won't have to climb underneath if my logic is right. If not, I'll start looking at the entire system.
Joe Bob 05-11-2013 05:48 PM
Plastic gear took the death march.
Send it out for a repair or do it yourself. More than a couple of threads on this.
Some say it isn't a bad repair.....my expereince is send it the the pros.
The bezel needs to be pried off like a can of Spam......then installed back.....easy to screw it up.
80-911SC 05-11-2013 06:19 PM
what he said ....
search or call hollywood speedo or paloalto
porwolf 05-11-2013 06:44 PM
Every SC has that problem. Just had my 79 SC speedometer repaired at North Hollywood Speedometer. Fast turn around, couple of days, re calibrated. $130. Probably will go for another 30 years.
pete3799 05-11-2013 06:58 PM
1979 uses an electronic speedo....no cable ( unless you mean electrical cable).
Ship it or try fixing it yourself. I got lucky and repaired mine with no trouble.
http://forums.pelicanparts.com/porsche-911-technical-forum/196987-odometer-gear-replacement-electronic-speedometers-long.html
autobonrun 05-11-2013 07:14 PM
Thanks. When they are sent for repair, can they keep the mileage on them or must they be reset?
Nico911 05-11-2013 07:41 PM
My advice : don't mess with it, send it to the pros
I had the very same problem and sent mine to North Hollywood Speedometer. It took 2 weeks to have it back (from Montreal) and it's back in the car. I'll road test it tomorrow but I assume it should work...
If you do send it to repair, don't forget to mark you wires. On mine, there were 11 wires...
Nico
Cooper911SC 05-11-2013 07:45 PM
They will keep the mileage as is unless instructed otherwise.
(I actually had them add miles to our 993 as my wife had to keep driving it for 50+ miles a day while it was out for service)...yep, I'm honest and like to keep accurate mileage. ;-)
Cooper
Nico911 05-11-2013 07:51 PM
Cooper
Cooper. Funny you mention this. I could have the mileage reduced on mine and resale the car with a greater profit in a few years and nobody would have noticed (car is in a very good shape and doesn't show his 138k miles), but I can't stand dishonest behaviors like that, so I didn't. :p
procan 05-11-2013 08:39 PM
I did it myself. Really not that difficult.
autobonrun 05-11-2013 08:54 PM
They will keep the mileage as is unless instructed otherwise. <br>
<br>
(I actually had them add miles to our 993 as my wife had to keep driving it for 50+ miles a day while it was out for service)...yep, I'm honest and like to keep accurate mileage. ;-)<br>
<br>
Cooper
Same here. I'll add about 100 miles put on since it broke. I'll pull it tomorrow and toss the cover on the car until it gets back.
80-911SC 05-11-2013 08:57 PM
You can drive it with it out ... you wont hurt anything .. just be aware of your speed ...
Joe Bob 05-11-2013 08:59 PM
Howz that OCD doing.....?
25+ year old cars.....who gives a rat's patootie....
Mine has 300K on the roller. Gotta badge on the grill....speedo say 23K.....
autobonrun 05-11-2013 09:21 PM
That's good to know although I'll probably take this opportunity to swap out for several weeks. It's supposed to hit the upper 80's next week and I don't have a working A/C on the SC. I'll take this opportunity to fix the speedometer and the steering wheel bushing. I noticed up and down movement in my steering wheel the exact day the odometer failed.
While I wait on the odometer fix and parts for the steering wheel, I'll put some miles on the C4S. I was looking for an excuse to swap out. ;)
Old photo, the 993's been lowered from SUV height since this picture, with PSS9's and clear corners added.
http://forums.pelicanparts.com/uploa...1368332396.jpg
