matt gineo's Avatar
Is my Air Box Shot??
Is there some method short of removing the airbox to determine the condition of the Airbox??
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 05-11-2013, 08:54 AM
a.k.a. G-man
Geronimo '74's Avatar
That depends.
Old 05-11-2013, 08:59 AM
Hook up a cleaned out vacuume in reverse to the intake snorkle and tape it up tight! Turn it on and spray soapy water all over the airbox and intake!
Old 05-11-2013, 09:01 AM
matt gineo's Avatar
thanks Jeff great advice. Geronimo not so great advice.
1962 356 C- sold
Old 05-11-2013, 11:22 AM
fastfredracing's Avatar
Or find a local shop with a smoke machine.
No left turn un stoned
Old 05-11-2013, 01:38 PM
Senior Advisor
James Brown's Avatar
Matt vage, general requests usually result in the same response. try to be more specific on what you are doing, what you want, symptoms your having, etc. it's hard enough to troubleshoot over the internet but a clear picture would help as well as pictures.
as far as looking for leaks, pressurization with smoke is a good choice, look around the injectors as this is known source of leaks. Also, pop off valve sometimes leaks. the split line is also a trouble source along with all the hoses and lines. The list is pretty long
08 Cayenne Turbo
Old 05-11-2013, 02:59 PM
matt gineo's Avatar
James, I agree with you 100% the more information the better. A photo of the airbox would not have shown anything and my question was pretty straightforward. Either your airbox leaks or it doesn't and I simply wanted to know how to check it for leaks without dropping the engine to remove said airbox. I received a few very good responses including your own, thank you.
I still don't understand Geronimo's response.
Matt
1962 356 C- sold
Old 05-12-2013, 09:10 AM
Senior Advisor
no engine drop required i remove them in the car
08 Cayenne Turbo
Old 05-12-2013, 10:45 AM
pretty easy to pull the entire CIS with a partial engine drop...gives you plenty of extra room. can completely rebuild the CIS rubber parts (hoses and boots) and reinstall...couple of the nuts on the runners can be a pain to get at and retorque, but all manageable...recommend doing it the same time you need and oil change...as it is best to disconnect the oil hose from the tank to prevent stretching/breaking it when you are lowering the engine.
Old 05-12-2013, 11:21 AM
