Fubawu's Avatar
Rennsport group 3 in car and tv coverage. 1971 911S ST 2.5
Hi
I thought you might like to see this video from Rennsport. In car and tv coverage together. Video shows a 20th place start and shows my progression through the field. This is the Eiefel group 2.0-2.5 911 and 914
https://m.youtube.com/watch?v=QAObQTokEtA
Old 10-27-2018, 04:09 PM
Great video and awesome driving. Car handle well. I was watching your steering wheel movement and your car handles very well. Very enjoyable to watch.
Old 10-27-2018, 07:13 PM
Great drive by a good driver.
Seems his car was set up and powered nicely for track.
Many guys driving race track. He was racing.
Big Diff.
PCA, POC & SCCA long time Member
Old 10-27-2018, 07:30 PM
Fubawu's Avatar
Thanks guys, cars was really solid. We had an issue in qualfying so we started towards the back. The only changes I would make to the car would be longer 2nd and shorter 3rd and 4th gear along with more rear camber. These two changes would have allowed me to make a run at the lead. Such a great event , can't say enough good things. Machine-Motorsports, EuroTune and Klubsport we're all a big help
Old 10-27-2018, 07:38 PM
John,
You were really peddling that car around the track. The car looks to really be dialed i You are real comfortable great driving, extracting the potential of the car without it biting back. Your other video with Ralphs old car is a good example of the amount of time needed to dial a car in after you have all the components in place. Even with a pro driving just a small detail like the shifter will put an end to the day. Been there done that. Awsome video and big efford to get those cars such a long tow from behind the cheese curtain
Old 10-27-2018, 09:43 PM
JED
ARCSinAK's Avatar
Nice work!
Old 10-27-2018, 10:04 PM
Olsen911's Avatar
Laguna Sega
John.
That´s awesome, brilliant drive.
It looks like a great set-up and you are really making some power in that ST.
Thanks for sharing.
Thanks - Olsen911 - Tommy Olsen
“I will not demonstrate it, I will race it.” Juan Manuel Fangio
Old 10-28-2018, 12:51 AM
Perfect blend of man and machine , as evidenced by ,among other things, the gentle slap on the steering wheel @ the 10:22 mark,- for delivering the perfect output for the given input at the given moment - man I would love to have that kind of rhythm.
1979 SC
1986 Carrera 3.6 L+
Old 10-28-2018, 08:21 AM
kent olsen's Avatar
Great video. Enjoyed it. Your where making good power but also good brakes. If you can't get them out of the corner you can get them going in.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 10-28-2018, 09:51 AM
Fubawu's Avatar
Thanks for watching...brakes are relatively stock. Early S calipers front and m calipers rear with hawk dtc 70/60 pads. Slotted rotters. Power is approx 285hp and 2050 lbs .
Old 10-28-2018, 10:58 AM
Fubawu's Avatar
I thought I would post some pictures of the car.
Old 10-28-2018, 03:27 PM
Todd Simpson's Avatar
Very cool, thanks for sharing.
Are those Hoosier TDR's? How do they compare to something like a Toyo R888 or a Hooiser R6 or R7?
Old 10-30-2018, 07:08 PM
Fubawu's Avatar
Hi Todd
Hard to say as this was my first time at Laguna. In regards to comparing them to R7's or 6's I think the grip on those can't compare. I would put them on par with R888'r's
The new r888 is hands down better then the old tire.
I was under tired in the rear of this car and will make the adjustment in the spring.
www.machine-motorsports.com
1971 911T 3.2 1971 911S 2.5
1972 911S 2.8 1972 911T 2.7
1965 911 300760 1976 911S
Old 11-02-2018, 06:52 AM
Fubawu's Avatar
A few more changes being made, going with Bilstein RSR rear shocks better rebound and lighter (saves 2lbs), new lite weight tail light set up from Rothsport (saves 5lbs) Adjusted the way the two coils are mounted (saves 1lbs) Brembo rear alloy calipers from the early 70's saves another 5lbs!!
Will also do another alignment as the car needs a little more rear camber. I'm debating changing the gearing to longer 2nd and shorter 3 and 4. I'm wondering if going with a lighter flywheel might help with being slightly out of the power band on corner exit. 3 -4 of the corners where an issue. Not worth the extra down shift but bogging slightly on exit. Need to squeeze a little more out of it if I'm going to catch Patrick Long
Old 12-10-2018, 08:32 AM
AirBorne!
subscribed... go man go
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 12-11-2018, 05:07 AM
RonDent's Avatar
Oh, I remember this race. I remember because this was the race group Patrick Long usually runs in. That and I was the Starter for this race. I remember most of the race I started.
'78 Targa Sold!
'84 Carrera Sold!
'01 996 Wrecked
Old 12-11-2018, 01:47 PM
