Loosening a distributor nut??
I have a 1970 911 Targa. I'm going over the dwell, timing etc but have been stopped in my tracks by a 'simple' problem. How is the nut loosened on the distributor to set the timing? Is there a special tool to do this? I can't get a ring spanner over it because of the distributor and their is limited room to manoeuvre a regular 13mm spanner. This could prove to be a stupid question but hey, if you don't ask!!
Old 05-15-2013, 12:23 AM
Taking it apart is easy
Jerome74911S's Avatar
Use a ratchet wrench with an extension on it, along with a 13mm socket.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-15-2013, 03:44 AM
1/4 drive, extension, one of the peices which allows you to turn a socket from an angle and a 13mm socket...loosen slightly before you have the car running...very careful with the car running...when tightening just tighten enough to hold in place then turn off engine and tighten as needed...
Old 05-15-2013, 05:59 AM
Bill Verburg's Avatar
I bought these crow foots decades ago, the realy long one is for an Alfa, the others 911
Bill Verburg
Old 05-15-2013, 07:01 AM
