Upier's Avatar
1986 911 Muffler strap queston
What is the difference between the left and right muffler strap for 1984-86 911s? Are the different lengths? If so what are the two lengths. I have one strap but don't know which one it is.
Old 03-28-2007, 10:12 AM
Welcome to the board.
This is the best I could do while the muff was on the car....
Warren & Ron, may you rest in Peace.
Old 03-28-2007, 10:36 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Rick...just to make sure...is this installation correct...I mean...is it ok that the strap pass over the heat exchanger cross over tube...???
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 03-28-2007, 11:50 AM
I only took the muff off once to add another tailpipe. I believe I reinstalled the same way it was done at the factory.
Old 03-28-2007, 12:20 PM
Seems correct. Here's a pic that Keith Craver (KC911) posted in the past:
Old 03-28-2007, 12:30 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
OK...that's look fine...mine don't pass over it...but it's a Monty...
<IN GAS WE TRUST>
Old 03-28-2007, 12:40 PM
TroyGT's Avatar
My 86 is the same way with the factory muff... right side strap is longer than the left and passes over.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 03-28-2007, 01:44 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Same with my 87- strap passes around the heat exchanger stainless tube.
Actually when you think about it? The strap passes around the tube because it's the only major support the tube has. If not for the strap, the only things holding the tube to the car are three hose clamps and the associated rubber couplers.
Kevin L
'86 Carrera "Larry"
Old 03-28-2007, 03:23 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
If you give a look to the cross over duct...you will find a welded bracket on...that bracket is supported by the driver side strap...!
<IN GAS WE TRUST>
Old 03-28-2007, 03:38 PM
Schleprock
KTL's Avatar
Thanks for the correction. I forgot about that. Still proves the straps hold the tube in place!
Kevin L
'86 Carrera "Larry"
Old 03-28-2007, 03:44 PM
Upier's Avatar
Thank you for the help and pictures.
Old 03-28-2007, 06:48 PM
thx
Old 06-08-2013, 10:14 AM
