-   -   A sort of barn find (http://forums.pelicanparts.com/porsche-911-technical-forum/750371-sort-barn-find.html)
Matthew Barnes 03-13-2018 04:38 AM
Never ends...
http://forums.pelicanparts.com/uploa...1520944572.jpg
The R vents on the fenders were a mess. Neither even vaguely symmetrical.
Matthew Barnes 03-13-2018 04:41 AM
Needed to do all the prep work so I could try and get these to work.
http://forums.pelicanparts.com/uploa...1520944765.jpg
Then very very carefully rebate the edge so that the grille frame sits flush.
http://forums.pelicanparts.com/uploa...1520944830.jpg
Matthew Barnes 03-13-2018 04:42 AM
Final version will look something like this....maybe
http://forums.pelicanparts.com/uploa...1520944927.jpg
Matthew Barnes 03-14-2018 04:21 AM
And more of this.
http://forums.pelicanparts.com/uploa...1521029700.jpg
Matthew Barnes 03-14-2018 04:27 AM
After a lot of sanding with 220 grit wet the primer was ready for topcoat.
I'm doing this in my garage so there will be a lot of sanding to make sure I get a decent finish.
Here is the colour.
Not exactly OE!
http://forums.pelicanparts.com/uploa...1521030200.jpg
Matthew Barnes 03-14-2018 04:32 AM
Have learned a lot spraying primer.
But still some way to go.
So there is safety in knowing I'm going to be doing a lot of sanding.
http://forums.pelicanparts.com/uploa...1521030535.jpg
Matthew Barnes 03-14-2018 04:36 AM
Consistent orange peel!
But the coverage is good.
This will get 400 and 600 wet before final topcoat and clear.
Although not sure whether I'll go with clear.
http://forums.pelicanparts.com/uploa...1521030757.jpg
Blinkx 03-14-2018 11:25 PM
Just read you full thread mate and have to say you have done an amazing job and can’t wait to see more.
Keep it up
Matthew Barnes 03-15-2018 12:15 AM
Keep it up
Thanks very much. Appreciate the encouragement.
Matthew Barnes 03-15-2018 12:24 AM
More and more sanding and checking panel gaps.
I must have fitted and removed these fenders over 100 times.
I am beginning to realise that my ambition exceeds my ability!
The third go I have had at the FBG fender edges.
I guess I should have just it properly the first time.
http://forums.pelicanparts.com/uploa...1521101765.jpg
I have managed to find the perfect piece of kit for fitting the hood.
His name is Finley.
Fender edges and hood edges are much better.
I can safely say that all FBG parts are not created equal.
My advice is to buy the best quality you can afford.
These were made by a 'master craftsman' who is putting his name to a brand of South Africa outlaws that have received a lot of press lately.....
A bit like those ads that say 'expertly restored, not a cent to be spent'
MBAtarga 03-15-2018 05:22 AM
Great thread and very cute helper there! He probably has visions of driving the car some day!
MadeofOak 03-15-2018 06:26 AM
Incredible amount of work! Keep going, almost there :) :)
Eharrison 03-15-2018 12:01 PM
Great panel gaps Matthew, glad to see you hammering this out! Hopefully I'll have some doors shortly and can start on gaps as well!!!!
Matthew Barnes 03-23-2018 10:08 AM
Thanks very much. He has his sights a bit higher: gt2rs! I blame Forza.
Matthew Barnes 03-23-2018 10:09 AM
Thanks very much. Need to get this thing done!
Matthew Barnes 03-23-2018 10:11 AM
Thanks man. You see that I took inspiration from your fenders.
Top tip with doors: you can always clamp a 2 x 4, vertically to the door when it's bolted in and give it a twist to make it align!.
Matthew Barnes 03-23-2018 10:16 AM
Bought my self one of these.
http://forums.pelicanparts.com/uploa...1521828778.jpg
Test on v2.
Running a bead down the centre for strength.
http://forums.pelicanparts.com/uploa...1521828845.jpg
V2 had the edge worked over in a buck.
http://forums.pelicanparts.com/uploa...1521828888.jpg
The final version will be laser cut alu, so I needed to be bit more accurate.
Matthew Barnes 03-23-2018 10:19 AM
http://forums.pelicanparts.com/uploa...1521829019.jpg
A bit of messing about.
V4 will need some pre-stretching.
And it would be great to have a set of tipping dies, to work the edge of the cut-outs.
Now have to transfer the drawing to a PDF so the laser cutters can do their work on 1/1.2mm alu.
Matthew Barnes 03-23-2018 10:48 AM
Originally Posted by Flojo (Post 9959396)
of ****!! get well soon!!
great build so far. much respect for THIS mega effort!
Cheers!
I've just seen this now.
School fees!
All good now.
Good scar though.
Matthew Barnes 01-10-2019 04:17 AM
Happy New Year fellow Porsche nuts. Been a while since I last updated this rather long build thread. The good news is that there has been progress.
2018 was a pretty busy year so I only did a few months' worth of work. Most of the time I just couldn't muster the same level of energy as I have over the previous years. Working FBG panels, panel gaps and tiny imperfections etc is exhausting. But that was 2018.
This project will be finished by June this year. Hopefully by mid-April if everything goes to plan.
Matthew Barnes 01-10-2019 04:58 AM
Finally got these installed. I have a factory alu engine lid that I will eventually install, but I thought it was better to make a mistake(s) on the FBG lid...considering my track record.
http://forums.pelicanparts.com/uploa...1547126781.jpg
http://forums.pelicanparts.com/uploa...1547127715.jpg
Nice result.
Next step was to repair some of the previous owner's work on the petrol tank. They had installed a OE filler neck in the middle of the tank. So I removed this, installed a new breather, and closed up the hole. Then welded in a filler neck to fit under the bootlid.
Everything was going fine until I had an idea.
Now buy now I should know that when I have an idea, I should write it down and leave it for a week - until the madness passes.
Alas....
So now I have another job on my list.
I really know how to complicate life for myself.
Matthew Barnes 01-10-2019 05:13 AM
This idea is to use the dimple in the existing tank in the newly fashioned shape. Hmmm. We'll see if that plan comes to fruition.
I will, regardless, add some baffles to my new 'custom' tank.
http://forums.pelicanparts.com/uploa...1547128878.jpg
Matthew Barnes 01-10-2019 05:22 AM
The CAD template.
I may well be looking for a 2nd hand tank....
http://forums.pelicanparts.com/uploa...1547130120.jpg
Matthew Barnes 01-10-2019 05:38 AM
Door cards.
Had these laser cut out of 2mm Alu.
The idea is to work a bead down the lengths to strengthen them.
BUT, the bead roller has rather sharp edges on the female die.
Which scores the edges when working the steel. So these will have to radiused....need to find an idle lathe.
http://forums.pelicanparts.com/uploa...1547130285.jpg
Got a whole bunch of stuff back from the platers. They did a great job.
Some bits will go back along with all the MFI hardware, but overall a great result.
For comparison, here is condition of the stuff supplied to them - they did all the cleaning and prep work. For R500...which is about $40!
Matthew Barnes 01-15-2019 01:57 AM
Rebuilding and servicing all the suspension parts.
Steering rack.
Stripped, sand blasted, cleaned, painted, lubed and upgraded with some turbo tie-rod ends.
http://forums.pelicanparts.com/uploa...1547549657.jpg
Matthew Barnes 01-15-2019 02:02 AM
Front suspension, with all new bushes, refurbed OE torsion bars, new ball joints and bearings. Alu calipers look great.
Boiling water, some dish wash liquid and an old sash clamp made the job a bit easier.
Working with nice clean, plated hardware makes such a change from the dirty, oily toil of the last 5 years!
Slight issue may raise its head: I have a set of oriignal hydrostatic shocks from an E that have been gutted and Bilstien'd. There may not be enough clearance between the original front anti-roll bar and the strut housing.
Anyone have experience of this?
http://forums.pelicanparts.com/uploa...1547550003.jpg
Matthew Barnes 01-15-2019 02:06 AM
Rear suspension.
No new bearings (which may prove to be a mistake) but everything else is once again new or refreshed.
http://forums.pelicanparts.com/uploa...1547550188.jpg
And after 5 and a bit years, the rear wheels turn!
A sandblasting cabinet is a wonderful thing. Have got carried away many times.
Decided to refurb the horn.
Matthew Barnes 01-15-2019 02:15 AM
Same treatment for the wiper motor and mechanicals.
And the MFI.
Must be about 2 kg's of hardware that comes off the MFI.
All of this will be replated and reinstalled with new gaskets.
Also gives me a chance to give the motor a proper clean; removing all the ancillaries.
Must be another 2kgs of oil, grease and dirt in all the crevices.
http://forums.pelicanparts.com/uploa...1547550461.jpg
Flojo 01-18-2019 01:07 PM
Originally Posted by Matthew Barnes (Post 10311815)
that lid needs a nice grille... from this dude: spadescustomz.shop
Matthew Barnes 06-13-2019 02:13 AM
A few updates on the build.
Finally managed to remove the remainder of the snapped suspension bolt. 1cm sheared for some reason and the Easyout was no good. What a b@#stard of a job. Rather than put the car back on the jig and turn it on its side, I decided to 'just' drill it out in situ......
http://forums.pelicanparts.com/uploa...1560420123.jpg
http://forums.pelicanparts.com/uploa...1560420223.jpg
http://forums.pelicanparts.com/uploa...1560420572.jpg
http://forums.pelicanparts.com/uploa...1560420722.jpg
Matthew Barnes 06-13-2019 02:20 AM
With that done I could finally get the refurbished steering assembly back into the body. And get these onto the car.
http://forums.pelicanparts.com/uploa...1560420993.jpg
Managed to find reasonably priced, good quality tires with a period-looking side profile.
http://forums.pelicanparts.com/uploa...1560421049.jpg
The titanium lug nuts from this forum look pretty awesome (and beautifully made btw).
Matthew Barnes 06-13-2019 02:30 AM
Next job: reassemble the window frames.
Stripping them was a bugger of a job - those little screws that hold the frame together were very happy to stay where they were, despite a fair amount of persuasion and lots of four-letter words.
I didn't want to have them rechromed and lose all the patina (under the muck and dirt)
http://forums.pelicanparts.com/uploa...1560421470.jpg
So cleaned up the rust, the solidified rubber seals and gave them some love with 1200 grit water paper, finishing compound and then metal polish.
I think they look awesome - fit the rest of the car.
Matthew Barnes 06-13-2019 02:36 AM
Back to the door cards.
A mate softened the edges of the (cheap) dies on his lathe.
Beware that the Harbour Freight-type bead Roller is a great tool for the likes of me, but the die edges are pretty rough and will need softening.
After a lot of measuring (and 4 hand-cut prototypes) I took the plunge.
Not exactly Rod Emory quality, but I'm happy with the result. Again, fits with the rest of the car. And hey, I made them myself!
Flojo 06-13-2019 02:42 AM
cool Panels!
great worc.
this could get the ROCS-Award (Instagram: rocsmotorsport)
Steve F 06-13-2019 03:49 AM
Like em!!! Vert nice!!http://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat.gif
Matthew Barnes 06-13-2019 04:20 AM
On to the door glass, locks etc.
The pull release for the door will finish up as multistrand rope rather than bungee cord.
The lifting strap seems to work okay but the weight of the OE glass makes lifting the window a little tricky.
http://forums.pelicanparts.com/uploa...1560428241.jpg
Matthew Barnes 06-13-2019 04:29 AM
Pedal box.
This has been keeping me up at night.
The original RHD pedal box was missing the clutch pedal and was generally rotten.
And to make matters worse, the bracket on the other side of the tunnel that accepts the clutch and accelerator shaft was also missing.
The accelerator is rotten as well.
The LHD box I have is missing a brake pedal.
The 964 box I have in the cupboard is rather complicated, and also LHD.
So I decided to try and save myself a 1000US and fabricate a solution.
I cut up the LHD clutch pedal and welded it back together and fabricated a pin through the welded shaft to accept a return spring.
I also drilled out the end of the clutch pedal so that it could accept a solid steel 10mm shaft for the carrier bracket.
The accelerator pedal is made out of chopped-down square tube, with the remnants of the LHD 964 accelerator bracket welded onto the back.
All in all it seems to work well, and will finish up nicely once it has all been tumbled and plated.
I'll only finish up the welds and plating once I have fitted the clutch cable, gearbox and accelerator cable - to make sure travel and tension in the return springs are sufficient.
Matthew Barnes 06-13-2019 04:38 AM
Then there are these buggers.
I was dreading having to import a set of period correct sport seats. They are very expensive once you factor in the 14:1 exchange rate, shipping and taxes.
So, as luck would have it, a mate of mine bought a '65 Cooper S and decided to get rid of the seats: a set of 1960s after-market Paddy Hopkirk buckets. SCORE!
I'll get hold of some suitable seat rails and weld up some brackets.
They look fantastic and are very very comfortable (for my 6'2" racing snake frame!).
I'm in two minds whether to have them redone or to just have them patched up and cleaned.
For harnesses, I was given these time-expired Willans by the same very generous mate. The hardware will be electroplated gold/yellow, the same as all the fasteners. The locks will be anodised black and the harnesses will be made up with new black webbing by a chap at the local airport who restores vintage aircraft.
Matthew Barnes 06-13-2019 04:45 AM
Finally, the last bit of progress.
The original visors are pretty nasty.
Being the curious chap that I am (meaning I take stuff apart without thinking about how I am going to put it back together) I decided to cut one open to see what the inner frame looks like.
Surprise, surprise.....rather beautiful.
And then my lovely wife suggested an idea....
The ply is just crap workshop ply. If the plan doesn't change I'll source some fine grain marine ply and have it laser cut to fit.
Matthew Barnes 06-13-2019 04:54 AM
In between jobs I have been giving the engine a refresh.
Just hardware, shroud and covers.
The shroud was knackered and cracked so that got a whole bunch of new fibreglass repairs.
Once the hardware from the MFI has been replaced and refitted, I think it'll look like a million bucks - whether it actually works or not is something we'll have to find out.
