Euro Height - Torsion Bar Cover to Floor Measurement
We have always talked about measuring the height from the fender to the floor.
Does someone have the equivalent measurements:
"torsion covers (both front and rear covers) to the floor"
Does this curiosity even make sense? I am just asking for people with previous body work.
Thanks.
Old 11-26-2007, 07:02 PM
Front Axle:
torsion bar center to wheel center...108mm.
Rear Axle:
bottom edge of torsion bar to wheel center...16mm.
25.4mm=1 inch
Old 11-27-2007, 05:04 PM
Thanks.
Out of Curiosity:
1. Was your car professionally corner-balanced?
2. what is your height measured from the fender?
Old 11-27-2007, 07:49 PM
1. No
2. Since my tires are 215/60 16 all around which is quite a bit bigger in diameter than stock, my fender heights would not be an accurate comparison.
Old 11-27-2007, 11:54 PM
burgermeister's Avatar
Originally Posted by stlrj View Post
Front Axle:
Rear Axle:
25.4mm=1 inch
Correct me if I'm wrong - it's early, I am without caffeine, and my memory sucks anyways...
The front measurement is below the wheel center.
The rear measurement is above the wheel center, and it is also to the torsion bar center (according to my fuzzy memory anyhow).
Bentley says for older cars up to 10mm lower is within spec.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 11-28-2007, 02:47 AM
Front Axle:
Rear Axle:
25.4mm=1 inch
per Spec Book, not memory...plus or minus 5mm.
Old 11-28-2007, 05:23 AM
stlrj - I don't claim to know the contents of the spec book - I don't have one. Looks like Bentley and the spec book disagree - now I'd like to know which tome is correct.
This is scanned from my Bentley:
It shows the torsion bar center as reference, located above the wheel center.
Old 12-01-2007, 08:27 AM
Interesting.
I just rechecked my Spec Books and a found the same discrepancy between my 78...81 Spec Book and my later 84...87 911 Carrera Book which is the same as your Bentley...go figure.
That means that if you go by the earlier 78 Book, your rear would end up about 1" higher than the using the later 84 Spec Book. Take your choice.
Old 12-01-2007, 04:56 PM
HKZ Bob's Avatar
Front Axle:
Rear Axle:
25.4mm=1 inch
Hi can you confirm the load condition for me again.
108 mm is defined with an empty or full gas tank. Do you have to add. extra load to the trunk?
BR
Bob
Old 05-19-2013, 12:38 AM
Mo money = mo parts
The easiest way to measure what burgermeister posted is with a laser level. You can see the level in front of the the rear tire. I stacked up some wood blocks and used the built in level with the adjustable feet. I was right in the middle of using the triangulation method when I took this photo. Both front tires are off the car and the weight of the front end is resting on a single fulcrum point in the middle of the front cross member. There was a great thread explaining this method to achieve a corner balance, I am just repeating the concept.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-19-2013, 05:09 AM
When Porsche introduced the impact bumper cars, the specs were 108mm/8mm + or - 5mm. The cars were raised (at both ends, by differing amounts) as the bumper laws changed and as they got fatter in the SC and Carrera years the torsion bar sizes changed, along with the ride heights. If you want to put your car back stock, use the numbers in the spec book for your year. If you want to change it, consider first what your car weighs and what bars are in it. If you want to lower it, 10-12mm is what is possible by raising the steering rack to compensate. There's not much room to move the rack.
JR
Old 05-19-2013, 09:34 AM
tazzieman's Avatar
This has some good points re ride height Ride Height Way Too High
esp post #22
But you neglect to mention that factory Euro spec is less than 1" lower at the rear and 3/8" lower in front than US spec. Pick up a Spec Book and verify for yourself.
What we are accustomed to seeing are 911s lowered to what looks good to the owner, which is much lower than Euro spec and beyond optimum ride comfort or handling parameters. The big misconception that we all seem to have bought into is that all 911s that have been lowered are automatically Euro height.
If I attempt to lower mine below that height , the front T bar adjusting lever loses contact with the crossmember (at full droop) and I get the most annoying rattle over bumps. Mind you I do drive on potholed surfaces , it's not a boulevard cruiser.
Ride height can be changed by pulling on pushing on the rear (if Bilstein equipped) , plus varying the weights of trunk contents and driver/passenger/luggage. Plus the built in factory tolerances. If you add it up you might be surprised! The average diy can spend (or waste!) a month of Sundays playing with the visually appealing vs functionally appropriate/optimal equation. I figure the factory got it right for the majority of us!
Even if this makes you cringe
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-20-2013, 03:01 PM
