Senior Member
Natchamp's Avatar
Roll Bar Recommendations ???
Ok, I really need to put front and rear roll bars on the Beast. I have checked out SmartRacing's and they appear to be ov very high quality but are also a little spendy. Are there any other options that are a good bang for the buck?
Mark
The Beast
mark@hargett.com
www.HargettPrecision.com
Old 07-19-2002, 12:28 PM
I put the Autopower bar with removable cross brace and harness bar in my 78SC. Bolt in but you have to drill through the floor pan and engie fire wall. Well constructed and relatively inexpensive. They are available here in San Diego.
Old 07-19-2002, 12:42 PM
Roll bar or anti-roll bar - aka "sway" bar.
Never heard of 'front and rear roll bars'
Old 07-19-2002, 01:10 PM
Sorry I thought you meant front and rear roll bar as in "full cage roll bar."
Old 07-19-2002, 01:23 PM
Senior Member
Natchamp's Avatar
Sorry for the confusion. I am referring to anti-sway bars.
Mark
The Beast
mark@hargett.com
Old 07-19-2002, 02:18 PM
Administrator
Jack Olsen's Avatar
IMO, it makes sense to go with cheaper (Weltmeister) in front, and better (SmartRacing) in back. It's a simple piece, but the Weltmeister rears are not a very good design.
Old 07-19-2002, 02:21 PM
Senior Member
Natchamp's Avatar
Thanks Jack. I think I need to determine the impact of having the G50 too. I might have a clearence problem with the bottom of the tranny. A straight bar might not work?
Mark
The Beast
mark@hargett.com
Old 07-19-2002, 06:20 PM
Platinum Member
dad911's Avatar
Jack, on both of my cars the 'square hole' in the weltmeister front bars have loosened up to the point where they can not be fixed. If it is for a heavily used track car, I would probably want to look at a different bar for the front also.
Old 07-19-2002, 06:24 PM
Administrator
Jack Olsen's Avatar
I snapped an AJ-USA one up front twice. Maybe TRG or Smart Racing or the like is the only smart way to go.
Old 07-19-2002, 07:25 PM
Hilbilly Deluxe
emcon5's Avatar
Time out,
We are talking about Mark I built-my-car-and-engine-from-the-ground-up-slapped-a-G50-in-it-still-working-on-the- Electro-Pnematic-Sequential-Shifter Hargett here.
Mark, go down to Home Depot, pick yourself up some 1" black gas pipe and whip yourself up a set of sway bars.
Tom
(Joking, but without a doubt that Mark coud do it)
82 911SC Coupe
GTI Cup #43
Old 07-19-2002, 08:26 PM
Mark, I have an '87 with a G-50 tanny and the SRP bars work like a champ. I have them front and rear and they are wonderful. Good luck
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 07-19-2002, 08:33 PM
