Battery vent hose routing.
I'm told it's an easy thing. I can't find a hole that routes out to the bottom of my 84'.
There is none, just leave it off or let it just hang downward
I drilled a hole in the body side....
grab an agm battery and never worry about a vent hose again.
I also drilled a hole, put a grommet, then ran a hose as far as the bottom of the windshield washer tank, far from any body sheet metal. I was a bit of a pain ....I dropped the washer tank to gain access. Those battery vents will let acid and fumes out, over time will cause damage. Of course for $$$ you can buy an Optima.
there are lots of agm batteries out there, not just optimas. this is the one i have used for the last few years with no problems at all, including leaving the door open one night and draining it. it's $80 shipped. Kinetik 600 Watt 12V Power Cell KHC600 - Newegg.com |
if you used to have a/c and now have a metal panel filling the hole where the blower was, that's a good place to drill a hole to run the vent hose. that's what I did.
| All times are GMT -8. The time now is 07:03 AM. |
