Battery vent hose routing.
I'm told it's an easy thing. I can't find a hole that routes out to the bottom of my 84'.
Old 05-19-2013, 06:07 AM
Member 911 Anonymous
DRACO A5OG's Avatar
There is none, just leave it off or let it just hang downward
'85 Carrera Targa
PCA/POC
Old 05-19-2013, 08:23 AM
wwest's Avatar
I drilled a hole in the body side....
Old 05-19-2013, 09:03 AM
nineball's Avatar
grab an agm battery and never worry about a vent hose again.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 05-19-2013, 02:29 PM
ganun's Avatar
I also drilled a hole, put a grommet, then ran a hose as far as the bottom of the windshield washer tank, far from any body sheet metal. I was a bit of a pain ....I dropped the washer tank to gain access. Those battery vents will let acid and fumes out, over time will cause damage. Of course for $$$ you can buy an Optima.
Old 05-19-2013, 02:41 PM
nineball's Avatar
there are lots of agm batteries out there, not just optimas. this is the one i have used for the last few years with no problems at all, including leaving the door open one night and draining it. it's $80 shipped.
Kinetik 600 Watt 12V Power Cell KHC600 - Newegg.com
Old 05-19-2013, 07:24 PM
schumicat's Avatar
if you used to have a/c and now have a metal panel filling the hole where the blower was, that's a good place to drill a hole to run the vent hose. that's what I did.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-20-2013, 07:05 AM
