bcgreen's Avatar
Clutch pedal distance
Should the clutch pedal be the same distance as the brake when at rest? There is a difference of about 3" in from the brake pedal.
Old 05-20-2013, 10:11 AM
They should be close to the same. My clutch pedal is slightly higher than the brake pedal but only by 1/4", if that.
Lou
Old 05-20-2013, 10:18 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Also mention that you can actually pull the pedal up 3"s , You need a cable adjustment, let me know and we can tackle it together. You will need 2 15MM wrenches and a digital caliper for measurement.
Jim
'85 Carrera Targa
PCA/POC
Old 05-20-2013, 11:08 AM
The brake pedal is adjustable so you either make them equal or you can set it at nice height for toe and heel braking, my preference.
Chuck.H
'89 TurboLookTarga, 352k miles
Old 05-20-2013, 11:12 AM
bcgreen's Avatar
This looks a little different than what's on Pelican's help file, but is this the clutch adjustment section?
Old 05-20-2013, 03:24 PM
What year Porsche do you have? It matters. On my 88 both pedals are at about the same level. On the 70 the clutch pedal is lower than the brake and the clutch free pedal is measured by pulling the pedal back. I would think that 3" difference is way too much.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-20-2013, 03:51 PM
bcgreen's Avatar
This is a '76 Carrera 2.7. So, what do you think of the photo?
Old 05-20-2013, 03:53 PM
bcgreen's Avatar
Jim
Thanks, Jim for the offer. I would like to try it on my own as this seems to be a no brainer. What do you think of the pic?
Old 05-20-2013, 03:55 PM
DRACO A5OG's Avatar
If on the trans, that would be it. you need a helper as you take measurements
'85 Carrera Targa
PCA/POC
Old 05-20-2013, 05:34 PM
