SC horn not working
My 83 SC went from horn working to not. Horn button is connected appropriately and everything is good under the fender. When I press the horn button with my hand on the relay I feel the relay click - does that indicate a bad relay or not? I pulled it out and made sure all the contacts were good, the only thing I can think of is a bad relay. Just wanted an opinion before I bought a $28 relay.
cheers- |
Member 911 Anonymous
Swap it with another one next to it. Check the horn connectors are getting juice when button is activated.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Yank the pad from tHe steering wheel and look at thE contacts (pull straight off) try bridging it directly with a jumper wire.... Mine were corroded and a bit of sandpaper and dielectric grease fixed it.....
J 911 SC - 1980 911 S - 1977 |
