pedal cluster 80 sc
Now that I have gotten the pedal cluster out, cleaned up, and ready for reassembly I have a question about the bronze bearing kit I bought for the rebuild. Do I need to "tap" the different bearings into their respective locations? I assume they do not just slide into place. I ask because I do not want to bugger up the inside of any of the cluster pieces. Thanks. Beany
Mine went together with just hand pressure. If it does not you have some issues.
Be sure to soak the bushings overnight or longer immersed in some oil and use a good quality light grease on assembly.
Jay Traner 1984 911 targa 1923 STuTZ 690 Touring 2014 VW CC 2.0T 2021 Subaru Forester (Mrs) |
I had to tap the accelerator bushings onto the shaft. Once past the clip groove, it was very free and slid easily.
Mine is an 87', but the bushings for the accel I believe is the same as yours. My brake and clutch however still use the original plastic bushing design for my MY.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
No tapping necessary, normally
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Arnage
Largely depends on condition of components. Rust, paint, corrosion, etc. can make assembly more difficult. These clusters tend to be rusty and that will distort receiving surfaces.
2014 Cayman S 2002 Boxster Race/Track Car 1971 914-6 GT Tribute 1962 Triumph TR4 FIA Rally Car |
I was able,with a little sandpaper and soft work to clean things up and get everything fitting nicely. Finished the day by cleaning all the pedals, etc and painted them. Looks sharp. Thanks.
