-   -   Would any one know where to obtain lug nuts like those used by "Singer"? (http://forums.pelicanparts.com/porsche-911-technical-forum/751555-would-any-one-know-where-obtain-lug-nuts-like-those-used-singer.html)
911dean 05-24-2013 08:40 PM
The bead blasted look is exactly what I'm looking for. Unfortunately I was not aware that these were available, as I already paid for the others. I'll have to see what I can do.
Dean
quozl 10-01-2014 07:31 PM
Lug Nuts from Jimmy arrived today and are beautifully made.
Thanks to Jimmy for his brilliant work.
Cheers Al
cabmandone 10-02-2014 03:54 AM
I'll have to look but I think I have a set of open end lug nuts from my donor car. I'm just not sure how many I have if there are still in one of my boxes.
douglas bray 10-02-2014 04:08 AM
My next set will be yellow zinc from SMC. I've got the open ended steel in black but agree that this is the way to go:
911 / 356 Porsche Parts | Porsche, Wurth and Fuchs Wheels | Sierra Madre Collection
997Sbeebe 10-02-2014 06:38 AM
that 'glass bead' option is beautiful. has a great retro/semi-magnesium look to it. i just ordered 'opens' as well, but for use with a set of Fikses. at $10/pc., price isn't bad at all - over what standard steels will cost you.
KTL 10-02-2014 07:04 AM
I told ya the lugs from Jimmy would be top shelf quality. :D
Regarding the yellow zinc from Sierra, i've had plated steel lugs in the past and the plating tends to chip/flake off at the edges of the hex tooling. I suppose it depends on how you treat them. If you take them off & on with hand tools, they should be fine. If you remove them with an impact gun, they'll probably chip.
911SauCy 10-02-2014 07:14 AM
I was about to purchase Rennline Opens, but it asks for Ball or Conical seat type.
My gut tells me my stock aluminum are ball seat, what kind of Porsche/wheel would have conical?
KTL 10-02-2014 07:41 AM
Rennline may have chosen to offer two styles of seat since there are aftermarket wheels that use the more common conical seat. I bought a set of ROH wheels years ago and they came with conical lugs.
This website gives you some good information on the different styles of lug nut seats. Track-Studs brand racing wheel studs and lug nuts Click on the ball seat category in the left sidebar navigation menu and then on one of the M14 nuts. Then click the "Detailed Information" tab and you get some interesting info (well, interesting to nerds like me at least.... :D) that says there's also different radius used on the ball/spherical seats
Porsche steel lug nut used to replace the alloy lug nut on all Porsche's with a wheel stud conversion completed. Black Oxide, oiled finish. Now mandated for some car clubs, eg. PCA, NASA, SCCA etc.
M14x1.5mm with R14mm radius ball seat. Never use 'other' ball seat nuts with R13 seat. Use the correct Porsche nuts. Use ACS nuts! (sold individually)
For use only with OE type Porsche wheels with original ball seats.
(note: conical seat wheels require our 60 degree nuts)
douglas bray 10-02-2014 07:48 AM
If we were talking chrome, then yes, treat them with kid gloves.....but we are not.. They are likely made by Verbus and sourced at SSF like the vast majority of German parts we buy. Take a close look at some of the Urban Outlaw cars. Same nuts.:cool:
KTL 10-02-2014 08:05 AM
Sorry I should have been more clear that the lugs I had were indeed zinc plated, not chrome. Just basing my statements on my actual hands-on experience with use of the plated nuts over a period of several years. Here they are:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/655951-steel-lug-nuts-full-set-20-a.html
911SauCy 10-02-2014 01:05 PM
I mislead you on that one KTL.
Can you confirm my gut that the stock lug nuts would be directly replaced by the ball seat and not conical rennline types?
My nuts look like balls to me...
KTL 10-02-2014 01:10 PM
Yep the stock lug nuts are ball/spherical seat style.
997Sbeebe 10-02-2014 01:17 PM
semantics! :D
NoLift911 10-03-2014 01:08 PM
Where can you get the press in bull nose lugs, vs. the screw in types for later cars?
KTL 10-06-2014 07:35 AM
Sway A Way makes a couple bullnose studs in lengths close to stock.
SWAY-A-WAY - axles, torsion bars, and shocks for trucks, cars, and off-road vehicles - Wheel Studs and Nuts
MSI also makes them in whatever length you choose. But in talking with a few friends about them, it's pretty expensive when you've got a small order.
MSI Racing Products (click on metric wheel studs)
ProSystems gets them from MSI since they're in the same neck of the woods in NC
Pro-System, Inc.
