1988 G50 Needs new clutch
I had an issue with the shifter bushing and it seems I will need a new clutch along with the bushing. Over 200k miles on the vehicle, so looks like I have several options:
1. Quote was about 4000.00 to do the clutch. That I thought was high, but also included fork and any seals that need replacing while the engine is out. Not major seals but thermostat seal and maybe one other.
2. I remember reading members in the LA/South Bay area doing a clutch for about 2200 with parts and labor.
3. If I try and do it with a freund, (practicing my German, just in case) what kit should I order on PP?
So, I found this on Pelican. Good write up.
Item Qty Part Number Description
1 1 PEL-TOL-CA3 Clutch Alignment Tool
2 1 930-107-764-01 Oil Filter
3 1 911-606-230-00 Oil Pressure Switch
4 9 930-101-206-00 Flywheel Bolts
5 1 950-116-080-08 Throw Out Bearing
6 1 950-116-813-06 Updated TOB Guide Tube
7 1 930-116-014-02 Spring Clutch Disc
8 1 Bronze Bushing G50 Shift Fork Shaft Update Kit
9 2 90011901702 TOB Guide Tube Bolts 6mmx15mm cheese head
10 1 950-116-023-03 Pressure Plate
11 9 900-067-045-02 Pressure Plate Blots
12 9 N012-241-8 Pressure Plate Washers
13 1 931-102-111-00 Flywheel Pilot Bearing
14 1 999-113-426-41 Flywheel Seal
15 1 931-102-111-00 Pilot Bearing
16 1 000-043-024-00 (Porsche) Olista ® Long time Grease Special Grease
Old 10-04-2014, 05:23 PM
Wow! Who pays $4000 to replace a clutch? Where are you located? Maybe a local pelican can help. My G50 clutch was way, way less than that. Will send you a pm.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-05-2014, 04:06 AM
rnln's Avatar
In Scal, I got 3 quotes year ago. $5000+, $4000, and $2000. I picked the $2000 after talked to a recommended mechanic from this board . Turned out to be $2200 . Let me look for the mechanic who did it for me.
I think this is the place. Parts and labor, include upgrade involved with machining some parts. I picked the spring type. It makes some noise at a certain low RPM. I very rare fall into this situation.
AASE Motors
1104 E. Elm Ave
Fullerton, CA, 92831
United States
Phone: 714.992.2283
Fat butt 911, 1987
Old 10-05-2014, 04:45 AM
Project Addicted
Once you have the engine out...you get on the very slippery slope of "while I'm in there" thinking.
Things to consider:
New fuel lines if they have no been replaced. (this is a must do)
Fuel injectors cleaned.
valve adjustment
Head Temp Sensor
Triangle of death reseal
Rear brake line replacement
CV joint repack
Rear control arm bushings. (Nearly IMPOSSIBLE to get at with trans in place)
It gets out of hand, I know.....
Get a kit from Pelican and see if you can do it yourself. Removing the engine and trans isn't that hard and there is some great instructions here and in other places online. Good luck!
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 10-05-2014, 05:10 AM
steely's Avatar
no real experience in clutches yet, but just an observation after looking at your list, you have pilot bearing listed in there twice (same pn anyway) - items 13 and 15.
more slippery slope dept': consider replacing the speed and ref sensors if the insulation isn't cracked - use BMW parts - same bosch quality at half the price.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-05-2014, 08:23 AM
I live in Hermosa Beach, but though the price was extreme. I get the slippery slope of replacing other parts while the engine is out. But this only included clutch. The hours involved might of been recorded high. 2000+ is palatable. I will call AASe in Fullerton. Does anyone have another recommendation. LA or Orange county is ok.
JCSlowcom: Good list, what is the triangle of death specifically? That might be a good update to do while the engine is out.
Looks like I will do the clutch, head temp sensor and triangle of death reseal. Is that the same as the rear seal? xxx
Get a kit from Pelican and see if you can do it yourself. Removing the engine and trans isn't that hard and there is some great instructions here and in other places online. Good luck![/QUOTE]
Old 10-05-2014, 10:34 AM
This Kit Includes:
SACHS Pressure Plate
SACHS Clutch Disc-Spring Loaded Hub
SACHS Release Bearing/Kit
SACHS Special Lubricant
So this is another option I have, its under 900.00, not as intense as the super kit, but this may just do the trick. the super kit is around 1500..
Old 10-05-2014, 03:19 PM
E-85 sippin drunk
turbobrat930's Avatar
Contact Jim Patrick at Patrick motorsports. They are in AZ, and will have all the clutch parts you need in stock... everything from stock to full on racing clutch parts.
Porsche & Mid Engine Performance Specialist By Patrick Motorsports Porsche & Mid Engine Performance Specialists
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 10-06-2014, 05:24 AM
0396's Avatar
Scott's Independent in Anaheim and TRE in North Hollywood.
Old 10-06-2014, 07:01 AM
Pelican Super Clutch Kit - 911 Carrera
I just had this put in my 88 911
everything you need right here in one order !
I had other stuff done "while I was there" so
I dont know price for clutch job by itself.
Old 10-06-2014, 07:11 AM
