I can feel a strong vibration thru the accelerator pedal when I get up into the higher rev.'s. anyone else ever experience this? what was the solution?
"87" Coupe with a 3.2 running thru a G50 |
The most common reasons are problems with the pressure plate and disc, ignition misfires, fuel delivery issues, and recently installed, out-of-balance components.
Without a thorough history of your car, its difficult to tell you much beyond this.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I'd check the motor mounts (first)......
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
87 also.....I get like a slight buzzz at ~ 2500 or so thru the pedal also. Not sure from what.
BTW Looking thru TSBs I found one that says to loosen and retighten the bolts that attach the sheetmetal rear engine mount to the case, if it continues (customer complaints) flip the engine mount washers so the are away from ea other, i.e. )-( rather than (-).
The closest way to describe it would be like stepping on one those old gag hand buzzers it happens around 5000rpm
Max Sluiter
Does it smooth out above 5000 rpm? Could it be a little bit of a misfire? Maybe just one cylinder?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
