very little clutter...that's how i would like my dyno sheet to look too.
Ok, now you have to give us the full specs of this engine.
What heads is this running? What Cams? Details on the COP? Also interested, did you take a reference off the cam for timing? |
Engine specs
This engine runs DTA S60 engine management, wasted spark, no sync. sensor.
Bosch TPS used as load sensor MAP sensor for baro comp Bosch air temp sensor 993 RS flywheel 60-2 with 993 Bosch reference sensor Four 3 channel ignitors Omega high comp. pistons Elgin cams Proprietary cast aluminum heads Proprietary 2 pin connector COP Intake uses Early RSR plug hold down tabs Exhaust uses no hold downs, COP screws onto the plug, tops push on like stock ones Rothsport stainless headers with our own design v-band secured connector pipe GT 3 Cup muffler with factory engine bracket and straps We have another build like this engine in a 964 that has slides with our own design screw in stacks that makes 436 hp. This one is wasted spark also. http://forums.pelicanparts.com/uploa...1370107044.jpg http://forums.pelicanparts.com/uploa...1370107081.jpg http://forums.pelicanparts.com/uploa...1370107108.jpg |
Andreas |
More intake options
Rothsport GT3 carbon intake. It weighs 6 lbs. compared to the metal factory @ 12 lb.
http://forums.pelicanparts.com/uploa...1370140023.jpg http://forums.pelicanparts.com/uploa...1370140047.jpg |
Now all we need is a sound clip of her running :)
Fancy stuff, wish I was rich :D
Sound clip
Rothsport Racing '97 Porsche 993 RSR Strafing Runs - YouTube |
oh my .....
Road test
It is even more amazing when you are there live!
Scotty, does the car in the video have the gt3 cup exhaust?
Exhaust
No, this engine had the Magnaflow muffler and older version headers we used in the past. Our new headers and GT3 muffler are on the car now.
Dyno video 3.9 435hp Rothsport Slide Valve
Rothsport 3.8 Yellow 993 ENGINE DYNO
Oh chit! I want one, but of course would have to sell all the Enron stock.......oh wait never mind.
wow wow wow
been looking for itb's for mine, this looks even better...wow...
I see in this pic of the exhaust there's a massive gap between the valve covers and the exhaust - is that to increase cooling/decrease exhaust to valve transfer? Is that possible in a NB car or only cos you have those mamma hips on the GT2 body? Or am I wrong and there isn't much to worry about from the collector pipe to valve covers/ig wires, and you just did that for the size of the GT3 muffler? |
That engine was one of our early builds a few years back. We are using our own design headers now and we do use a heat shield to protect the valve cover and coil on plugs.
http://forums.pelicanparts.com/uploa...1512418985.JPG |
super thanks for that - do you sell those headers/exhausts?
| All times are GMT -8. The time now is 04:55 PM. |
