Targa_PB_78_SC
Rear shock gap difference paranoia
I have an apparent difference in shock bolt gap.
![]() [img] ![]() The passenger side has bigger gap. Both were torqued to the 92 ft-lb, although I raised the trailing arm with floor jack per Wayne’s method versus Bentley which implies tighten with weight on wheels. Concerns? I’ve driven it 2400 miles and 12 months without issues. |
I would add a paint stripe connecting the head of the bolt to the washer and to the shock. This way it will be very obvious if it loosens up.
If you're not getting a rattle, the shock works the same.
It dampens the recoil. That lateral movement would not really many any real difference. Is the bolt head bent? Why not replace the bolt ?
1986 Bosch Icon Wipers coupe. |
Targa_PB_78_SC
That Guy
Did you check how the gap looks with the wheels on the ground? That gap will probably go away.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Targa_PB_78_SC
Well, I had new porsche bolts so I replaced the passenger side bolt. Threads on the old bolt looked a little warn. Then a omen came as the interior washer between the shock and the trailing arm lay on my garage floor. Suspect there is not a washer between the shock and the trailing arm on the drivers side; hence, less gap on drivers side. I seem to recall no washer present when I installed before, did not annotate though.
Added paint to passenger side. Consternation on adding a washer to drivers side. Thanks for all the thoughts and advice guys. |
Remove the bolt turn the shock 180 deg.
