DRONE's Avatar
Question Vibration
I can feel a strong vibration thru the accelerator pedal when I get up into the higher rev.'s. anyone else ever experience this? what was the solution?
"87" Coupe with a 3.2 running thru a G50
Old 05-24-2013, 08:43 AM
The most common reasons are problems with the pressure plate and disc, ignition misfires, fuel delivery issues, and recently installed, out-of-balance components.
Without a thorough history of your car, its difficult to tell you much beyond this.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-24-2013, 09:02 AM
dshepp806's Avatar
I'd check the motor mounts (first)......
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-24-2013, 11:54 AM
ganun's Avatar
87 also.....I get like a slight buzzz at ~ 2500 or so thru the pedal also. Not sure from what.
Old 05-24-2013, 09:39 PM
ganun's Avatar
BTW Looking thru TSBs I found one that says to loosen and retighten the bolts that attach the sheetmetal rear engine mount to the case, if it continues (customer complaints) flip the engine mount washers so the are away from ea other, i.e. )-( rather than (-).
Old 05-24-2013, 09:45 PM
DRONE's Avatar
The closest way to describe it would be like stepping on one those old gag hand buzzers it happens around 5000rpm
Old 05-25-2013, 08:05 AM
Max Sluiter
Flieger's Avatar
Does it smooth out above 5000 rpm? Could it be a little bit of a misfire? Maybe just one cylinder?
Old 05-25-2013, 10:40 AM
