930 oil leak question
So I have one the typical 930 issues- bought a low mileage car that has not been driven much, has recently been resealed, did not leak. Drove it 1000 miles home and it's developed a couple of leaks. The worst leak is coming from one of the oil lines that connects the oil tank to the front cooler. I tightened up the fitting, it was not very tight but did not fix leak, maybe a little worse. Do these lines need to be replaced, how tight should fittings be?
Thanks,
Phil
Old 05-25-2013, 11:15 AM
ROW '78 911 Targa
timmy2's Avatar
Solid or flexible line?
Post a picture of where the leak is coming from.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-25-2013, 03:11 PM
Dennis,
It's a flexible line with metal fitting on end, seems to have stopped leaking. It appears that there is now some oil coming down one of the air shields at front of motor, on drivers side, hard to see what is going on.
Phil
Old 05-25-2013, 09:09 PM
An oil leak on the top front of the engine is often the PCV line that has separated. Do you smell fuel\oil in the cabin after boost?
1987 GP White 930
1977 Ford Bronco
Old 05-25-2013, 09:45 PM
I don't but I'll check to make sure, it seems to have started all of a sudden.
thanks,
Phil
Old 05-25-2013, 10:18 PM
Forced Induction Junkie
WERK I's Avatar
Originally Posted by pu911 View Post
Dennis,
Phil
When you say "front of motor, on drivers side", are you referring to the end of the motor closest to the rear bumper or furthest away?
If it's the bumper side, there are two oil lines to look at. One is the small oil line feeding the camshaft oil tensioners. The other is the oil line feeding the turbocharger.
If it's furthest away from the bumper, more than likely it is the turbocharger sump pump fittings or the o-rings in the sump pump itself.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 05-26-2013, 05:29 AM
Dave,
I've checked those, they are good, it the end of motor towards tranny, I'll poke around some more today.
Thanks,
Phil
Old 05-26-2013, 09:05 AM
Ok did a little more digging around- here is a what I can easily see are issues, some sort of valve with broken hose, is this the PVC valve? Oil collecting on top of driver side HE, loose gasket between turbo pipe and IC, spilt inner CV boots, should axles and/or CV be replaced or can I just change out boots.
Thanks,
Phil
Old 05-26-2013, 10:46 AM
