about to replace my starter. not too hard right?
guys,
My car wouldn't start after sitting idling for a few minutes at costco gas station. nothing happened when I turned the ignition switch. my starter is dying. :( I bought a high torque starter to put in my 81 euro SC. I also bought the "piggy back" terminal splitter and 4 new 10mm washers. I jacked up my car and placed the passenger's front and rear wheels on 4.5'' blocks of wood. I plan on removing the heater hose first before removing the starter. Isn't it guys? Am i missing anything? Seriously i am a lillte worried. For some reason I m a little nervous. Probably lack of confidence and I have to be under the car. :D It is not a difficult job to tackle right guys? thankshttp://forums.pelicanparts.com/uploa...1369530816.jpg |
Here is all you need to know...Pelican Technical Article: 911 Starter Installation
Enjoy and report back with pictures when you are done!;) |
Don't forget to disconnect the battery before you slide under it.
A long 10mm Allen socket for your 3/8ths ratchet will help make the job go faster. -J
Not difficult but if those are the original nuts you may find it difficult to get sufficient leverage to break them loose. A little penetrant will help if you can see where you are aiming.
You just might run a OO wire to it whilest there....tie a string to the old one as you pull it out,,,then you have help snaking it back in
Snap a picture with your phone so you remember the wire configuration... I had good luck removing mine pay using penetrant oil, then tightening slightly, then loosening... A trick I picked up from this board when I removed my heat exchangers.... And extensions, yes....
| All times are GMT -8. The time now is 06:43 AM. |
