about to replace my starter. not too hard right?
guys,
My car wouldn't start after sitting idling for a few minutes at costco gas station. nothing happened when I turned the ignition switch. my starter is dying.
I bought a high torque starter to put in my 81 euro SC. I also bought the "piggy back" terminal splitter and 4 new 10mm washers.
I jacked up my car and placed the passenger's front and rear wheels on 4.5'' blocks of wood. I plan on removing the heater hose first before removing the starter. Isn't it guys? Am i missing anything? Seriously i am a lillte worried. For some reason I m a little nervous. Probably lack of confidence and I have to be under the car.
It is not a difficult job to tackle right guys?
thanks
Old 05-25-2013, 06:14 PM
French Import
zippy_gg's Avatar
Here is all you need to know...Pelican Technical Article: 911 Starter Installation
Enjoy and report back with pictures when you are done!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 05-25-2013, 06:18 PM
pete3799's Avatar
Don't forget to disconnect the battery before you slide under it.
Pete
79 911SC RoW
Old 05-25-2013, 09:13 PM
Go-Kart Mozart
JAR0023's Avatar
A long 10mm Allen socket for your 3/8ths ratchet will help make the job go faster. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 05-25-2013, 09:44 PM
walt's Avatar
Not difficult but if those are the original nuts you may find it difficult to get sufficient leverage to break them loose. A little penetrant will help if you can see where you are aiming.
Walt
82SC 3.0
81SC 3.6
Old 05-26-2013, 06:13 AM
Air Medal or two
afterburn 549's Avatar
You just might run a OO wire to it whilest there....tie a string to the old one as you pull it out,,,then you have help snaking it back in
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 05-26-2013, 08:16 AM
Guardsred911's Avatar
Snap a picture with your phone so you remember the wire configuration... I had good luck removing mine pay using penetrant oil, then tightening slightly, then loosening... A trick I picked up from this board when I removed my heat exchangers.... And extensions, yes....
J
911 SC - 1980
911 S - 1977
Old 05-26-2013, 11:19 AM
