airhead (guest)
Guest
Posts: n/a
Replaced oil tank on 1970, connected elec. wires to tank,don't know where to connect other ends.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Oil Level Sender Replacement - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 12:47 PM
Nick at Pelican Parts's Avatar
You should have 2 wires at the sending unit. One for the signal and one for the ground. I don't know what you mean by the other end? Did you buy a replacement harness? If you did then you have to run the wires all the way to the gauge in the dashboard.
- Nick
