-   -   it clicks when i move door to open? (http://forums.pelicanparts.com/porsche-911-technical-forum/752877-clicks-when-i-move-door-open.html)
donnie (guest) 05-28-2013 03:54 PM
door stay that i replaced works in 2 positions,but it clicks when i move door to open?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Door Stay Replacement and Reinforcement - 911 (1965-89) - 930 Turbo (1975-89)
Nick at Pelican Parts 05-28-2013 03:54 PM
Check to see if the door metal that supports the stay is not bent. It may be hitting because the whole panel is bent
- Nick
Targalid 05-28-2013 04:21 PM
"There are multiple threads on this. The John Walker fix is to use a 6mm bolt and nyloc nut in place of the press fit pin. Tighten just enough to prevent unwanted movement. No more pop. "
http://forums.pelicanparts.com/porsche-911-technical-forum/722496-question-snapping-sound-drivers-door.html
