Ed (guest)
Guest
Posts: n/a
The driver side window on my '91 911 Turbo wouldn't go down. I swapped the switch and it still wouldn't work. So I took the motor and the regulator out and tested the motor-it works. The regulator is also intact. Now, I'm thinking the window was only stuck? Does this happen? Or, could the motor be "weak" and need replacing? Any advice you can offer would be appreciated. Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your Window Regulator and Motor - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 04:05 PM
Nick at Pelican Parts's Avatar
Make sure the brown wire on the switch is a good ground. A broken ground wire will stop the window from working
- Nick
