David (guest)
Guest
Posts: n/a
I have bought the ignition switch from you already but in the process of removing the old one two wiring harnesses came off and I need to know which one goes where. Can you help me with a photo of the harnesses plugged in.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your Ignition Switch - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 04:34 PM
Nick at Pelican Parts's Avatar
You will need a wiring diagram to know where each of the wires go in the connector. It is much safer to just buy a new electric ignition switch
- Nick
