Regenerated User
Hoods
I've have hood issues going on for much of the past ten years.
When I first got the 911 the hood would mysteriously and voluntarily pop up on its own, usually in a turn. I couldn't tell by driving it, but I felt a little awkward every time I parked the car and walked around to the front to see what my hood had decided to do. Usually I had to push it back down again. I tried to change the height of the plunger (loosening the large nut and using a screw driver on the end to raise or lower it), but as a fix it never really lasted long. And when I replace the hood shocks the problem only seemed to get worse. I then bought a new lower assembly from our host and installed it after I had the car painted. This seemed to fix the problem of the hood from accidentally popping up. But since then I've had issues trying to free the plunger when trying to release it on purpose. The hood shocks finally quit working too...Shrug. But I was determined to fix this not opening issue one way or another. One day after fighting with the hood and winning, I had my wife pull on the release from the inside so I could observe the action in the lower assembly. It was working perfectly. It cleared the hole fine. So this was not the issue. I put a small block of wood to force the release open from the drivers seat and began shutting the hood and trying to open it again. I was trying to figure out why the plunger was sticking when it should simply move in and out. It was then I started noticing all these bolts the thing was fixed by. I quickly loosened them to see it I would move the top assembly and I could. Why hadn't I thought of this before? I loosened and tightened, tested and did it over and over again until it was perfect. I released the wood block and Hallelujah it worked over and over again. ![]() ![]()
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
Regenerated User
![]() ![]() ![]() Confounded! I spoke too soon. I just popped out for a Chinese takeout and viola the hood has popped up again, all on its own. I really don't want to drill holes in my hood for adding tie downs, but what else can I do?
Try:
Extend the mast a little. Lubricate and check that the latch operates correctly and the release is free. Align upper and lower. Old rabbit parts.
Its just a car. |
Functionista
Not being familiar with long hoods, does your car have rubber hood snubbers that you can screw in and out?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Regenerated User
I'll give it a try tomorrow.
Put a piece of painters tape over the lower latch hole and lower the hood till the plunger makes a dimple in the tape. Adjust till it hits dead center.
Another thing to check is if the plunger is bent (should be 90* to the mounting plate). Extend the plunger a little so that with a firm push it clicks shut. Don't be afraid to lube it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Regenerated User
I extended the plunger (mast) a full rotation. This does seem to help. I only noticed one pop up on a bumpy road, so I'm heading in the right direction.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 Last edited by 72doug2,2S; 05-29-2013 at 11:30 AM.. |
The cable needs to be adjusted at the front latch. The hood release is designed to open if the cable breaks, and there is a mid point where it latches and releases. It is a little bit of a pain to get the set screw on the cable set to the mid point, an extra set of hands helps.
Ed 1973.5 T |
