need advice
I am trying to help out my girlfriend. She inherited a 1981 SC. After installing a fuel pump, flushing the fuel tank and replacing a bad brake line I started to change the leaky valve cover gaskets. Upon removing the lower valve covers I found 10 out of 12 lower head studs broken. After removing the engine w/the help from friends I purchased Bentley's Porsche manual. After disassembling the engine down to the case I successfully removed all 12 lower studs. However when I disassembled the engine I separated the pistons from the cylinders. They are Mahle pistons & cylinders. Is there any way I can re-ring the pistons and reinstall them in the cylinders? The odometer reads 112,700 miles but the cylinders look brand new.
Old 05-28-2013, 05:54 PM
Did you mix up which cylinders go with which pistons?
Old 05-28-2013, 07:05 PM
Send a message via Skype™ to Porboynz
A new set of rings is OK, but check the end gap is within spec at different points within the cylinder (this will almost certainly be OK, as you note the cylinders often look new.) The more important check is the ring grooves in the pistons, slide the rings into the pistons and check the wear. The top and second ring are the most likely to be worn. No point re-ringing an engine with worn piston grooves, they will wear rapidly. If both these measures are within spec you are good to go. I did a light flexi hone on my barrels for the new rings, bedded quickly and been great ever since.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-29-2013, 12:29 AM
schumicat's Avatar
damn, 10 out of 12 broken studs must be a record of some kind.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 05-29-2013, 04:37 AM
T77911S's Avatar
he must not know that new guys must post pics of girl friends......or was that cars?
me, i would send the cylinders to be honed, heads for a valve job, rockers to be rebushed and cams to be polished.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-29-2013, 06:54 AM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Dude you need this book, TODAY. Its has everything you need to know.
How to Rebuild and Modify Porsche 911 Engines 1965-1989 by Wayne R. Dempsey
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 05-29-2013, 07:06 AM
irl irl is offline
irl's Avatar
And this one.
Porsche 911 Performance Handbook by Bruce Anderson
79 SC unmolested
25 GTS
Old 05-29-2013, 07:08 AM
