Lessons learned from mounting your fiberglass duck tail?
Hi guys - about to dive in to mounting my duck tail on the '74. I know the final fit will need some work to get right - that can wait until I get closer to paint - but I want to drive the darn thing with the duck tail on it before it gets too hot down here.
So - any lessons learned on how to mount the fiberglass tail? I know they are supposed to be reinforced where the trunk lid goes but...
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 05-28-2013, 07:07 PM
nineball's Avatar
step 1. do not install the plunger on the lid.
after that it's just playing with it, and washers, until you get it right. once it is perfect you can reinstall the plunger, then check for the correct plunger depth. yes it is adjustable.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 05-28-2013, 08:00 PM
duck tail
Make sure you cut out holes for your license plate lights and if you are going to mount an AC condenser, you will need to fabricate brackets to hold it.
Old 05-29-2013, 04:04 AM
Hellraiser's Avatar
Send a message via MSN to Hellraiser
Leave the grill out until the plunger is correctly adjusted.
I had it bound up with the lock because my first try wasn't ok
and had to break the thing open.
If you leave the grill out, you can always unbolt it from the inside.
Old 05-29-2013, 06:26 AM
moneymanager's Avatar
I never could get the tail to work with the stock lock assembly. After weeks of trying, gave up and installed hood pins to secure the lid. Hope you do better.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 05-29-2013, 06:35 AM
wannabee wannabee
WIL84911's Avatar
I've had to enlarge the mounting holes on the lock assembly to make it work. Hopefully you won't have to do that.
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 05-29-2013, 08:34 AM
Reiver
Reiver's Avatar
Drill some vents in the inner bottom fiberglass so water can escape properly. Best to have it a tad high in the back (at the hinges) and reduce down (washer spacers) so you don't chip/wear paint on the body lip where the DT rotates up and over under your back window. I also used some thin tape there.
Not that dif if it is a well cast piece.
Old 05-29-2013, 11:03 AM
vash's Avatar
are you going to swap back and forth? if so get a second set of hinges. pretty easy to do the swap at that point. you dont mess with adjustments.
tips? two people really help the cause. resting the lid on your head as you reach in is a poor substitute.
get rid of the hood shock/plunger thing.
poof! gone
Old 05-29-2013, 11:29 AM
Now accepting US $ at par
dienstuhr's Avatar
Get a Seine carbon prop to replace the hood shock.
Things That Go: World's Trickest Engine Lid Prop???
Cheers and have fun, it's a great look!
d.
1985 911 Carrera Coupe
2015 Volkswagen GTI 6-spd
some motorcycles
Old 05-29-2013, 11:39 AM
vash's Avatar
i made mine. well JP911 made mine with one of my old hunting arrows. carbon fiber. very similar. mine mounts at the bottom and pivot up to hook on a fastener. great.
just watch out for the wind picking up the lid and letting it slam shut.
poof! gone
Old 05-29-2013, 12:03 PM
Reiver
Reiver's Avatar
In the raw and not painted yet...was actually pretty easy to install...a bit of sanding to even out edges but all of the stock furniture fit and operates as the original lid...no issue with closing/latching. Worked the first time jus adjust for height.[IMG][/IMG]
Old 05-29-2013, 03:43 PM
4flyboy's Avatar
Reiver,
Who made your lid? Thx Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 05-29-2013, 05:04 PM
