Hellraiser's Avatar
Send a message via MSN to Hellraiser
Will a 964 C2 exhaust system fit a 3.0SC?
Quick question:
wil a 964 C2 exhaust system fit a 3.0SC?
(the entire thing: heat exchangers, cat and 2 mufflers)
Thanks!
Old 05-30-2013, 02:01 AM
Hellraiser's Avatar
anyone?
Old 05-31-2013, 04:45 AM
Eva
911SauCy's Avatar
No
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-31-2013, 04:48 AM
Hellraiser's Avatar
If no, why not?
I've already searched the net and found 3 answers
a) it fits
b) it fits but you need longer exhaust studs
c) it doesn't fit, the exhaust flanges are reversed, but by looking at pictures, the flanges look the same.
d) it fits with a 915 but not with a G50
I'm going to pick it up in an hour or so, but the price is correct, so I should be
able to sell it on for the same price if it doesn't fit.
Old 05-31-2013, 06:36 AM
Speed Dog's Chauffeur
Dodge Man's Avatar
Check out Steam Roller's Flange Machining
M2CW is that fitting the heads and clearing everything else are separate issues.
Check the last page of the Thread to see how to avoid changing exhaust studs: Thin Flange vs. Thick Flange Heat Exchangers
Old 05-31-2013, 06:58 AM
Eva
911SauCy's Avatar
Originally Posted by Hellraiser View Post
If no, why not?
a) it fits
You forgot the exhaust exit is on the wrong side of the car.
At the end of the day, you can MAKE anything fit.
Unless you got it for free, I'd say its not worth the aggravation.
My $.02
Old 05-31-2013, 07:02 AM
Hellraiser's Avatar
my car is already updated to a 964-look,
so the exhaust tip will be at the correct side.
the muffler I have now is completely shot (too much welding and too loud)
and the entire set for the C2 i can buy now is half the price for a custom
muffler for my car.
that's why
Old 05-31-2013, 07:06 AM
Eva
911SauCy's Avatar
Hell...try it out!
Worst thing that happens is it doesn't fit, was just tossing out pessimism to get the gears turning.
Old 05-31-2013, 07:19 AM
Will NOT work with a 915 transmission in a 3.0SC, don't waste your time or money!!
When I installed a 964 3.6 into my '80SC, I had to replace the 964 complete exhaust system
with one from a 3.2 Carrera due to a clearance problem with the 964 exhaust manifold
crossover and the 915 trans.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-31-2013, 07:20 AM
Hellraiser's Avatar
Ok thanks,
guess I'll have to wait another month to have a stainless steel muffler custom welded then.
Greetings,
Johan
Old 05-31-2013, 07:50 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
That picture above is also missing the secondary muffler and pipes and tip..
Old 05-31-2013, 10:26 AM
