islandrob/bob (guest)
Guest
Posts: n/a
Re: dealing with the 24mm nut for fan belt replacement. I see the end of the shaft has an allen wrench hole. In a pinch if you don’t have the proper pulley wrench can you use an allen wrench to loosen and/or tighten the nut?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Fan Belt Replacement - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-30-2013, 04:38 AM
Nick at Pelican Parts's Avatar
I have done just that in the past. Just be careful. Think about the size difference of the nut and Allen bit. If the nut is over-tight the Allen bit can break.
- Nick
Brorag
Brorag's Avatar
do you still have tool kit? Wrench in there.
Brorag
Old 05-30-2013, 08:55 AM
Taking it apart is easy
Jerome74911S's Avatar
Is this yet another Porsche design mystery? I have always suspected that this is the exact reason for that allen wrench hole. I'd use it in a pinch.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-30-2013, 09:00 AM
