horanoffp (guest)
Guest
Posts: n/a
1986 911. The two interior lights inside my car do not shut off when I close my doors. they worked fine a couple of monthe ago after I replaced the door switches. any ideas?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Troubleshooting Electrical Problems - 911 (1965-89) - 930 Turbo (1975-89)
Old 05-28-2013, 03:48 PM
Nick at Pelican Parts's Avatar
Push on the switches by hand and make sure the lights go out. Also make sure the switches on the lights are in the right position to go out with the doors closed. Someone may have accidentally moved them. Check to make sure the door is contacting the switches when they close.
- Nick
dshepp806's Avatar
Yeap,..light switch first...then on to the door switches.
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-28-2013, 04:38 PM
rokemester's Avatar
clean, clean, clean the switch contacts including wire spades. that helped me when I ran into this on my 87.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 05-28-2013, 04:43 PM
gptom's Avatar
The lights are 3 positions. Center works with door switch. one side on all of the time, other side off all the time
Tom
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 05-29-2013, 08:55 AM
Although this was posted yesterday to the forum, the question/comment on the technical article that it was generated from was dated August 26, 2012...
'77 S with '78 930 power and a few other things.
Old 05-29-2013, 04:54 PM
skinnerd's Avatar
The clear lens of the light actually "toggles" into 3 positions.
Reach up there in the headliner and try to move them....push in one end of the lens or the other.
It's possible you've toggled the lens into the always on position.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-30-2013, 09:15 AM
