Always Be Fixing Cars
Is the Wurth Matte or Gloss black correct to refinish Carrera Fuchs?
Want to refinish the Fuchs on my Carrera and wondering what supplies you all would order from our gracious host vs buy at home depot. I should say I'm looking for an excuse to order some stuff as I need some tiny bits and pieces that don't make sense to buy alone.
Matte?
Gloss?
From what I've read here and seen, the finish seems like its more of a satin. Are either of these correct?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 04-25-2013, 07:13 AM
Rustoleum 7777 Satin Black
Old 04-25-2013, 07:24 AM
Like this?
http://www.amazon.com/Rust-Oleum-7777830-Satin-Enamels-12-Ounce/dp/B00166QNGW/ref=sr_1_2?ie=UTF8&qid=1366903862&sr=8-2&keywords=Rustoleum+7777+Satin+Black
Old 04-25-2013, 07:31 AM
wurth matt black lacquer.
206 637 4071
Old 04-25-2013, 07:33 AM
cpa cpa is online now
r-mm, use the Worth matte black. You won't be disapointed.
Old 04-25-2013, 07:55 AM
I did some other bits & pieces with the rustoleum and it looked great, but for wheels I would probably cough up the extra dough for the Wurth. But people here have used both with great success. Just stay with the satin finish IMO. Glossy is too, well, glossy :-)
Old 04-25-2013, 09:16 AM
Well I called Pelican and they confirmed that neither Wurth product has the 'correct' gloss level, which I think is important to get right. I don't need perfection in the application, this is a driver, I just want a deeper black than I presently have on my chalky wheels. I'm inclined to give the Rustoleom or something like this a shot: Satin Black Wheel Paint 12 oz Aerosol
Can anyone share their prep / priming steps? Did you take the petals down to bare metal?
Old 04-25-2013, 09:41 AM
Rescuer of old cars
Arne2's Avatar
First time I repainted my centers, I used a can of Krylon satin black, as I already had a can on the shelf. Looked correct and nice. I'm refinishing them again (Fuchs faux-anodizing - what silver paint?) and am using the Rustoleum #7777 satin black. Also looks correct to my eye. So I'm guessing that most any decent quality satin black should be OK for a driver.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-25-2013, 09:47 AM
There seem to be a lot of votes for the Rustoleum option. I had a very good experience with VHT's wrinkle finish for my Alfa twin cam valve cover so this is also an attractive option: VHT SP183 Satin Black Wheel Paint Can - 11 oz. : Amazon.com : Automotive
Old 04-25-2013, 09:52 AM
i guess they don't have the matte black lacquer then. it's perfect.
206 637 4071
Old 04-25-2013, 11:35 AM
They do have the matte black (I linked to it above...) but I was told its less glossy than the factory finish.
Old 04-25-2013, 11:37 AM
Rescuer of old cars
Arne2's Avatar
Wurth makes (or made?) three different levels of gloss in black - matte, satin and gloss. I'd always thought the satin was the correct one for this. Griot's used to offer a nice German satin black, too. But I no longer see it on his website.
2018 718 Cayman 2.0
Old 04-25-2013, 12:28 PM
matte is not flat. it has a slight sheen.
206 637 4071
Old 04-25-2013, 02:09 PM
Got started stripping my wheels. Used a gel stripper and variety pack of wire brushes along with some scotch bright. Took a number of passes for sure but got two done in about 2 hours.
Old 04-25-2013, 05:38 PM
rokemester's Avatar
Are you trying to retain the original anodizing? I thought mechanical removal of paint with wire brushes would remove the anodized coating?
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 04-25-2013, 05:45 PM
I am trying to keep the anodizing on the rim and repaint what was previously painted. I'm not using power tools and trying to be careful around the rim.
If the paint was previously applied on anodized metal... well it won't be anymore.
Old 04-25-2013, 05:47 PM
ganun's Avatar
My 87 GP white coupe but with factory option white wheels.....My first reaction was to paint them black when I first got the car, white is absurd on wheels, or just stupid, but after some time I came to like them even though they are a PITA.
George Nunez
Old 04-25-2013, 06:02 PM
Recreational User
porschenut's Avatar
That's correct. The Rustoleum 7777 is NOT the correct match. It's too glossy. I've used it and compared it to brand new factory Fuchs. The correct finish is matte, not satin.
Old 04-25-2013, 06:39 PM
rokemester's Avatar
Cool! My Fuchs are a bit dinged up as it is, but after 26+ years they still clean up pretty nice with some Vaseline. Your wheels look to be in much better shape than mine. Look forward to watching your progress.
I cleaned up and painted the center caps at the end of the driving season last year.
Northeast Ohio
1966 VW Beetle, 6V
Old 04-25-2013, 07:01 PM
MConn's Avatar
Will 1 can of Wurth matte black cover all 4 wheels, or do I need 2 to be sure I have enough paint?
Mike
The more I learn, the less I know.
Old 04-25-2013, 07:15 PM
