bcheney's Avatar
Fan and Pulley match/mismatch?
I have an original 914/6 case with a standard crank pulley running a 245mm fan inside a 930 106 102OR housing (this is from a 80-83 911 or 78-89 3.3 Turbo). The outer pully half is p/n 603-421-01-M260 (from a 69-73 911). Does this mix of parts create a problem with the innner and outer pulley surfaces ie..are they different in pitch? What belt should I be running 9.5x710 or 10x710... or 9.5x725 or 10x725? Wow..I hope someone can figure this one out.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 06-03-2013, 07:41 PM
mskala's Avatar
This thread has I think all the info you need. And I think you should buy the
proper pulley half for your fan.
Question on Pully Size - for increasing cooling
Mark S.
'70 914-6
Old 06-03-2013, 10:48 PM
bcheney's Avatar
fan and pulley
Ok I have a late model 245mm fan housing and and earlier mid seventies 245mm fan and pulley. Here is a pic. What belt is correct for this set up 9.5 or 10 x 710 or 725?
08 Cayenne V6
75 914-6 Conversion
Old 06-04-2013, 05:04 AM
mskala's Avatar
If you have the crank pulley from 914-6, then everything is early and 710 should be
the right length. I didn't get it before that your fan is old, the housing isn't
important.
Mark S.
'70 914-6
Old 06-04-2013, 08:33 AM
kugelfischer's Avatar
I agree, you've got an old (60-73) fan and the right outer pulley half to match the fan.
The housing does not impact the equation.
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 06-04-2013, 10:42 AM
