Question on Pully Size - for increasing cooling
I've read somewhere on this site that you can aid cooling by changing the size of the pully.
My question are:
1) which pully gets changed - top or bottom
2) what is the stock size and what is the new size (I want to check to see if this has already been done).
Thanks............Vern
Old 06-27-2012, 12:23 PM
Use the 77 to 79 crank pulley and the 80 to 89 fan and pulley half and a 9.5x725 belt of the 77 through 79 911.
Bruce
Old 06-27-2012, 12:37 PM
The small fan pulley sizes are 3.125" or 3.25" (80 vs. 83 mm). The pulleys consist of "pulley-halves". You can't simply change one fan “pulley-half” without also changing the other "pulley-half".
1965-74/75.. 110 mm crank pulley..95 mm fan pulley
1976-77... 130 crank...83 fan
1978-79....130 crank... 80 fan
1980-89.....120 crank....83 fan
for fan sizes / blades / air flow:
1965-74/75....245 mm / 11 blade... 1.3:1 ratio..1390 liters air/sec
1975/76- 77.....245 / 5 blade.......1.8:1 ratio....1265 l/sec
1978-79...........226 / 11 blade ...1.8:1 ratio...1380 l /sec
1980-89.........245 mm / 11 blade...1.67:1 ratio...1500 l/ sec
fan belt sizes:
1965-75....9.5 x 710
1976-77.....9.5 x 725
1978-79....9.5 x 725
1980-on.... 9.5 x 710
BTW....aftermarket will sell fan belts at 9.5/10 x 710 as being "equal" to 9.5. Don't buy it. There have been reported problems with this. If possible, buy from dealer or Pelican and ask for the right size.
Early 911 245 mm fan with 1.3: 1 pulley ratio 1390 ltr/sec @ 6100 rpm
1976-77 five bladed fan with 1.8:1 pulley ratio 1265 ltr/sec @ 6000 rpm
1978-79 226 mm fan with 1.81:1 pulley ratio 1380 ltr/sec @ 6000 rpm
Fan Tip Speeds:
diameter (mm) rpm pulley ratio speed (ft/sec)
early 911 245 6100 1.3 334
76-77 5 blade 245 6100 1.8 462
SC 226 6100 1.8 426
930 245 6100 1.68 431
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 06-27-2012, 12:44 PM
Carrerax's Avatar
Does anyone know what length belt for an early crank pully (110mm) and a 78sc (80mm) fan pulley? Thanks, Mark
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 09-17-2012, 12:25 PM
Porchcar guy's Avatar
Perhaps the Porsche specialist at our host would have a quick answer via the 800 number :=)
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 09-17-2012, 01:07 PM
wwest's Avatar
My question are:
Engine..? Person (A/C)?
Old 09-17-2012, 01:44 PM
Engine = 2.7 CIS
Person = ?
A/C = No
Old 09-17-2012, 02:41 PM
mskala's Avatar
I have the early pulley mated to an 80-89 fan (83mm) and am using 10x695 belt.
Mark S.
'70 914-6
Old 09-18-2012, 09:59 AM
Carrerax's Avatar
Thanks Mark!
Old 09-18-2012, 10:03 AM
Functionista
manbridge 74's Avatar
PO installed 130mm crank pulley on my 74. OE was 110mm.
Fan pulley is still 95mm.
Belt size: 10 X 740.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-18-2012, 11:05 AM
Carrerax's Avatar
The 74 still had the larger fan pulley. I think I need the 695 or 700.
Old 09-18-2012, 11:10 AM
wwest's Avatar
My question are:
How can you be certain that turning the engine fan/blower faster than the factory design would not result in a "compressor stall" at the higher ranges of engine RPM rather than additional cooling...?
Old 09-18-2012, 01:31 PM
304065's Avatar
Math
A few more ideas for the Fan debate.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-18-2012, 01:33 PM
wwest's Avatar
Originally Posted by euro911sc View Post
Ideally you would want to regulate fan speed by CHT. CHT goes up fan speed goes up and the opposite. Connecting it to the crank like it is approximates this behavior.
But, the blades are not dynamic and therefore are designed for a specific air velocity which will translate into an RPM band for optimal flow. Is this band narrow or big? *shrug*
So... does it matter if we're running outside the optimal band for the fan, but are still flowing enough air to keep the CHTs down? I do not think so. If we are not flowing enough air then yes... Will we know this if we are measuring individual CHTs? or should it be CTs? Or combustion chamber temps?
John's work is good and would be really really useful IF we knew what speed the fan was designed for... Then you could gear it for your average RPMs... higher for street and lower for track... or maybe its reversed.. hehehe
How about an electric fan slaved to CHT?
I have no idea where it would go though... Maybe a side mounted alternator and an electric flat fan setup
Best regards,
Michael
WOW...!
Yet another reason for using 2 12 volt radiator fans to help cool the rear lid condensor....and..
The engine.
Old 09-18-2012, 02:24 PM
Chain fence eating turbo
I have MegaSquirt and can read CHT's at anytime. On 90-100 degree days, once fully warm, the CHT usually stays around the 300 degree F mark give or take 5 degrees.
Fan speed seems to not matter much.
Old 09-18-2012, 02:54 PM
wwest's Avatar
In heavy stop and go or slowing moving traffic...?
With A/C ?
Old 09-18-2012, 03:09 PM
Moderate traffic.
I should add I'm 7.5:1 CR so my data may not be accurate for most.
Old 09-18-2012, 06:13 PM
Wer bremst verliert
JohnJL's Avatar
Originally Posted by 304065 View Post
And real world experience.
I spin my fan and alternator at 2x normal speed and have stable voltage, good CHT, no knocking and good oil temps. I have ~20 track days with that setup with no issues.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-18-2012, 07:05 PM
