matt gineo's Avatar
CIS Test Equipment??
I want to learn how to diagnose and adjust the CIS system on my 1976 2.7. What diagnostic tools will I need and where is a good place to buy them?
Matt
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 06-01-2013, 04:58 AM
schumicat's Avatar
cis fuel pressure test kit, amazon, ebay, pelican.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-01-2013, 05:59 AM
pete3799's Avatar
Fuel pressure tester, digital volt meter,air compressor for vacuum leak testing and a test light should cover it.
Pete
79 911SC RoW
Old 06-01-2013, 06:18 AM
El Duderino
tirwin's Avatar
+1 on the fuel gauges. You'll need a fused switch to jump the fuel pump relay so you can do the CCP test.
You also need a good multimeter. If you can find one that can measure duty cycle that is nice to have. Or if you can measure dwell and convert it to duty cycle. My timing light has a dwell function built in.
You will need a way to check for vac leaks. Various approaches for this... spray a little carb cleaner, soapy water, etc. Do a search and you will find plenty on this.
Most people don't have an exhaust gas analyzer so you might have to take it to a shop that has one for that. I've read you can use the O2 sensor as a proxy (.7V) but I don't think your year model has one. Not sure how accurate that statement is anyway.
Old 06-01-2013, 06:25 AM
76 911S Targa
Matt,
I recommend you read up on the CIS system so you know what components you have that need testing. You definitely need a fuel pressure tester. Pelican sells a nice one. You have several components which are electrically activated: cold start valve, thermo-time sensor, auxiliary air valve, WUR, fuel pump safety switch on the air intake. These need a volt/ohm meter for testing. Our cars do not have a frequency valve like the later SC has so we don't need a dwell meter for that. No oxygen sensor either. For the injectors, a way to compare volume at the injectors, a graduated cylinder is useful. I can't think of anything else right now. Our injection systems are simpler than the later models. What we gain in simplicity, we lose in gas mileage, but not much. I am getting less than 20 mpg in town but around 24 mpg on the highway. What is nice about our CIS is that it is pretty much mechanical without a lot of electronics and therefore simpler to understand.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 06-01-2013, 06:51 AM
E Sully's Avatar
CIS Primer for the Porsche 911
Ed
1973.5 T
Old 06-01-2013, 06:56 AM
ROW '78 911 Targa
timmy2's Avatar
Bosch CIS fuel pressure tester from our host.
Gunson gas tester from ebay?
Quality multimeter.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-01-2013, 07:20 AM
matt gineo's Avatar
Beautiful, Thanks for all your help! I'm sure I'll be back with more questions once I get started.
1962 356 C- sold
Old 06-01-2013, 08:10 AM
Recreational Mechanic
Nickshu's Avatar
Add a CO meter to set mixture. I have a Gunson GasTester, works great! About $200 on ebay for a new one, I have seen used ones go for no less than $160 on ebay, so I bought a new one instead since it's only a few bucks more than the going rate for a used one.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 06-01-2013, 09:21 AM
