-   -   Emergency! 3.6 converted careers won't turn over in boonies! (http://forums.pelicanparts.com/porsche-911-technical-forum/753669-emergency-3-6-converted-careers-wont-turn-over-boonies.html)
p7guru 06-01-2013 07:39 PM
Hey, I just drove my new to me 88 carerra with 95 3.6 conversion from Philly to NC. I stopped to pee and it won't start! If you turn key lights come on but no turnover--not even a bit.
Any emergency tips? I am stuck and 7 hours from home!
wwest 06-01-2013 07:41 PM
Stick shift...Push to start
wildcat077 06-01-2013 07:45 PM
How's the battery ?
Check to see if the alternator belt is tight ... i guess without a voltmeter and basic tools there's not too much you can do.Perhaps try to get a push start and see if that works ...
I'm sure someone else will chime in with helpful advice !
Cheers
Phil
mreid 06-01-2013 07:51 PM
Neutral safety switch? Clutch safety switch?
Joe Bob 06-01-2013 07:55 PM
Whack the solenoid with a BFH......call the previous owner and ask WTF?
Check battery connections.....long drive w/o AAA?
EDIT: Yes hot start.....if you wait an hour it maight start.....whacking the solenoid frees it up.....
OsoMoore 06-01-2013 08:32 PM
Could be an overheated starter solenoid. This happened to me last summer. I was able to push-start the car. Later, when it cooled off, it started fine.
That issue is known as a heat-soaked starter. Good luck and I hope you get home safe soon!
b rock 06-01-2013 08:54 PM
Fuel pump relay?
p7guru 06-01-2013 10:14 PM
Easy fix! Stupid battery cable had corroded through. Took everything apart and cleaned it. Jump started good as new.
Thanks guys!
Joe Bob 06-01-2013 10:15 PM
Oi...JB pegged it....
