UPDATE: Petronix coil was oil filled. Many people have problems with oil filled if they are not mounted straight vertically with the wires being on the top. I recommend you buy the epoxy filled since you can mount it differently.
Old 06-10-2015, 06:33 PM
Changed the spark plug wires even though the old ones showed perfect 4 ohm resistance. Sync'd up the accelerators to 5cc at 10 full throttles and made sure they gave nice healthy squirts. Put everything back together. Car runs great! FINALLY!!!!!
Old 06-10-2015, 06:35 PM
Tags
marelli , mr-ls1 , permatune , s112bx , timing
