<insert witty title here>
Christien's Avatar
Chasing an oil leak
I just recently developed a fairly serious oil leak. The front of the passenger side heat exchanger is damp, and I'm thinking it's coming from the oil cooler right above it.
I hit it with degreaser and wiped eveything down and I'm not yet seeing any new dripping. I've circled the area that was wet in the pic. Any thoughts? Could it be something other than the oil cooler?
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-23-2013, 05:22 PM
thumbdoctor's Avatar
If the leak was the oil cooler you would see a leak soon after the engine is started. Look higher up because the cooling air tends to push oil leaks down from above.
Porsche, aucune comparaison
Old 09-24-2013, 04:36 AM
Christien's Avatar
The cooler wouldn't leak when the car's not running, would it? Or at least, would stop leaking 10 or 15 minutes after the car's off?
Old 09-24-2013, 07:26 AM
Elombard's Avatar
I think the o rings where the cooler attaches to the block are a 'common' leak area IIRC?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 09-24-2013, 10:10 AM
could also be coming from top of the engine (some common leaking points below the CIS)-very hard to see, but get a mirror and a light and try your best...and as the engine and tranny go together right near there...could be the rear main seal. Jack up the rear, clean it off really good...and fire up the engine and see if you find the source...
Old 09-24-2013, 12:06 PM
Christien - If you spill any oil while topping off/refilling, it will flow to the rear of the engine and end up dripping down the engine oil cooler. Did you recently add oil?
I had the same thing happen, and that was the issue. My shakey hands. LOL.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-24-2013, 12:21 PM
theiceman's Avatar
you call that serious ? come check out my car ..
Before you put the 3.0 in please tell me you did the trinagel of death ( thermostat oring, oil sender and cover )
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-24-2013, 12:32 PM
Christien's Avatar
Cleaned and checked when I transplanted the engine 18 months ago, but I've ordered new once to replace.
Already checked there - nice and easy with carbs and rainhats
Yep, but it was way low, and checked the dipstick while adding, so not overfilled. BTDT!
Yep, no leaks on the topside - nice and dry.
Old 09-24-2013, 01:15 PM
Christien - I did not mean overfilled. I meant spilled. As in your pour missed the opening, and oil spilled on your engine tins. From there it will drip down onto your engine oil cooler making you think you have a leak.
Old 09-24-2013, 01:24 PM
porche's Avatar
Christien,
Could you clarify a few things please?
* You cleaned the area good after discovering the leak, then restarted the engine to confirm the leak site?
* Oil only leaks when the engine is running?
* How much?
* Does it leak when the engine is off?
* How much?
1979 Indishrot 930, Rudolph
"Dad, buy it! Real race cars don't have sunroofs."
Old 09-24-2013, 02:11 PM
ROW '78 911 Targa
timmy2's Avatar
Next valve adjustment check the rocker shafts for leaking. Very common.
Old 09-24-2013, 02:25 PM
Christien's Avatar
Ah, 1972, my friend
Originally Posted by porche View Post
Christien,
* How much?
* How much?
Haven't restarted the engine yet. I've left it to see if it's pooling. I glanced at it this morning and nothing there from overnight, but need to check again. I won't be able to run it until tomorrow morning, so I'll check all this then.
It's not leaking from the valves - the covers are bone dry all along the bottom. That was the first thing I checked, as the valves were just adjusted last week.
Old 09-24-2013, 02:52 PM
Christien's Avatar
Ok, this is a bit strange. Fired it up, let it run for about 5 minutes, then got underneath to have a look. I think it's the rear main seal - it's dripping from the fore end of the case, and it's a pretty bad drip:
The puddle you see at the end is about 4-5 minutes of dripping.
But that doesn't explain how the front of the right heat exchanger got oil on it, and smoked. If it's the RMS, it should just leak onto the ground and not burn off.
The oil cooler wasn't leaking at all, so that's good news. But I'll be checking the heat exchanger again after a few days of driving to see if there's another leak.
Old 09-25-2013, 02:24 PM
E Sully's Avatar
When you drive the oil will be blown onto the heat exchanger.
Ed
1973.5 T
Old 09-25-2013, 03:24 PM
porche's Avatar
Looks like you've identified the source (out the hole at the end of the transaxle case and down the end of the crankcase seam). Static tests are best at identifying leaks. If you go out for a drive it begins to become a guessing game as there are a lot of different air currents in play under the car that can push the oil anywhere.
Old 09-25-2013, 03:25 PM
Christien's Avatar
I cleaned the area up again and dusted it with baking soda, then ran the engine for a few minutes. I think this clears up any doubt it's the rear main seal:
Old 09-27-2013, 07:42 AM
Christien's Avatar
Any other opinions, before I drop the engine and transmission to replace the seal?
Old 09-29-2013, 08:49 AM
E Sully's Avatar
Seems to be the seal. Set the new seal dry, and do not set it too deep.
Ed
1973.5 T
Old 09-29-2013, 09:54 AM
I have same problem after change oil, And more leak , i think come from 2 tube with nuts, i try tight . Can tell liters, of oil need, when dry engine, tank, And filter? I put 7 liter, is that to much?
Regards
Old 09-30-2013, 12:51 AM
Completely drained sump and tank + filter requires about 12 quarts (11.35 liters)
Old 09-30-2013, 05:15 AM
