sbmackie's Avatar
SSI's on and SC and the oil lines
Hello,
If one is putting SSI's on an SC, does one HAVE to buy the two oil lines? Not picturing what I'm moving.
What parts should I buy before digging in?
Reputable source indicated there was a work around that was just as effective, if not as pretty.
Anyone care to take a shot at 'splainen it to a person who recognizes a screwdriver 8 out of 10 times? Not that I don't use them...but the parts I have left over plum confound me.
Scott
Old 05-07-2013, 04:34 PM
ganun's Avatar
Simple, the answer is YES, the 2 lines.
George
Old 05-07-2013, 05:00 PM
ganun's Avatar
Expanding a bit....one all metal pipe from left front of engine that crosses the front. The other is part hose part metal pipe that connects to the first near the engine oil cooler then loops back, and runs forward to the oil thermostat. Need a special wrench to undo the connection at the tstat. If it is a connection that is original and super tight might damage the stat, not a fun job.
George
Old 05-07-2013, 05:10 PM
sbmackie's Avatar
Ganun,
Does the long one run forward to the thermostat, or the front mounted early carrera 28 row oil cooler?
Old 05-07-2013, 07:07 PM
I used this site, just received the two lines today, so they are legit, not cheap though-
Old 05-07-2013, 10:17 PM
Elombard's Avatar
Oil lines and oil pipes for Porsche 911 / 930 - Elephant Racing
You need 1A and 3A in the picture.
I have a used 1A available, I never got around to returning it. I will sell if for what I have in it which is 70% of the price of new I think.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-08-2013, 02:33 AM
I recently did this on my SC. I can see haw the SC hard line could be bent to work, but I'd be afraid that it would be subject to snagging and getting damaged. The revised lines are a very clean installation.
I replaced both soft lines back from the thermostat as mine were leaking. those connections at the thermostat were the only ones that gave me trouble, I ended up cutting the nuts rather than risk damage.
Old 05-08-2013, 03:47 AM
Elombard's Avatar
2nd on cutting the lines with a dremel - slowly, there is a lot of meat their but if you go in too crazy you could damage the T Stat.
Old 05-08-2013, 04:03 AM
sbmackie's Avatar
Ganun, what is the special wrench I'll need to take the oil line off the thermostat? And what other special tools will I need? I've heard of a tool SSI ships you. I bought mine used. Was ist?
Old 06-04-2013, 06:25 PM
Reiver
Reiver's Avatar
Don't need a special wrench just big ones a 34mm and 32 mm if memory serves right. Put Kroil on the threads for a few days and heat with a torch or run the car to temp...3 days at least soaking the threads.
Drop wheel secure the therm with one wrench and have at the other nut.
Old 06-04-2013, 06:46 PM
I used a crescent wrench, had no issues what so ever
Old 06-04-2013, 07:10 PM
