-   -   Location of cruise control circuit board? (http://forums.pelicanparts.com/porsche-911-technical-forum/754128-location-cruise-control-circuit-board.html)
RSBob 06-04-2013 07:42 AM
Have read the threads on what to repair, but where does the thing live?
ClickClickBoom 06-04-2013 08:13 AM
On the '84 Carerra right next to the brake booster behind the cardboard thingy. Silver aprox 5'x8', 2 phillips screws on the sides with a connector on the bottom.
RSBob 06-04-2013 08:20 AM
Sorry. On an 82. Probably the same. Will check tonight. Thanks
Nick Triesch 06-04-2013 11:09 AM
RSbob, My speed control would not hold a set speed, it would slowly drop off. I found a used unit on ebay for about $65.00 and installed it and it works great! You can also get your unit rebuilt.
nineball 06-04-2013 01:10 PM
yep, same location on an 82. almost directly in front of the steering wheel, wire plug goes on the bottom.
4flyboy 06-04-2013 06:11 PM
Hey guys,
No desire to hijack but I've an '84 with no sign of cruise control option at all....... is it possible to retrofit? Does the wiring exist? It is a factory Turbo look and I would imagine it was loaded. P.O. stripped a lot of weight......
