Did SC's have a factory "Buzzer"?
While I was under the dash of my '82 SC installing a new ignition switch, I noticed that the source of the annoying 10 seconds of buzzing every time I started the car was an after market buzzer box. A PO had spliced this thing in to the run signals from the ignition switch, and the key-in-ignition sensor. I removed it, because the added-in wiring was not done well, and I never cared for the buzzing.
Did the car originally have a buzzer that this was installed to replace, or did this guy just really love a the sounds of a buzzer? What was the key-in-ignition sensor was wired to before? Max |
Could it be related to seat belt warning?
I don't think this was around in 82 but if its after market then perhaps it was installed. Have you tried the ignition with th seat belts fastened? I would also suggest low beam lighting but I think it would be less likely that you turn the lights on before the car is running. |
Factory buzzer warns you the key is in the ignition. Opening either door triggers it. Sometimes there is a bit of a delay. Pulling the key out a bit stops it (stays off if key is pushed back in). Opening door with engine on also triggers it.
These were frequently disabled because the buzzer is so annoying. I tolerate it for the sake of originality. |
Mine quit working about a year ago on my '83. I didn't notice it for a while so I'm not sure if it just died or if I did something accidentally while I was fixing something else. Have to say I don't miss it but that will only last until I do something stupid like leave the headlights on and drain the battery.
US spec had a buzzer behind the gas gauge.
Yours may have been added as a requirement for importing a euro model as a seatbelt buzzer is a US federal requirement. I unplugged mine years ago. Only consequence on a US model is the seatbelt light will no longer Illuminate with the relay unplugged. |
Yep. I think mine is a Union Member...works when it wants to....
On some of the later cars (86-on I think) the seatbelt buzzer was tied to the interior lights wiring so that if you disconnected it or it stopped working your interior dome lights would no longer function.
