Did SC's have a factory "Buzzer"?
While I was under the dash of my '82 SC installing a new ignition switch, I noticed that the source of the annoying 10 seconds of buzzing every time I started the car was an after market buzzer box. A PO had spliced this thing in to the run signals from the ignition switch, and the key-in-ignition sensor. I removed it, because the added-in wiring was not done well, and I never cared for the buzzing.
Did the car originally have a buzzer that this was installed to replace, or did this guy just really love a the sounds of a buzzer? What was the key-in-ignition sensor was wired to before? Max
1985 BMW 325e - 2 Door 1982 Porsche 911 SC Euro Spec 1965 Land Rover Series IIa Restoration Project 1999 Land Rover Discovery II 2002 Suzuki SV650 Naked Bike |
Could it be related to seat belt warning?
I don't think this was around in 82 but if its after market then perhaps it was installed. Have you tried the ignition with th seat belts fastened? I would also suggest low beam lighting but I think it would be less likely that you turn the lights on before the car is running.
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
I am my 911's PO
Factory buzzer warns you the key is in the ignition. Opening either door triggers it. Sometimes there is a bit of a delay. Pulling the key out a bit stops it (stays off if key is pushed back in). Opening door with engine on also triggers it.
These were frequently disabled because the buzzer is so annoying. I tolerate it for the sake of originality. |
El Duderino
Mine quit working about a year ago on my '83. I didn't notice it for a while so I'm not sure if it just died or if I did something accidentally while I was fixing something else. Have to say I don't miss it but that will only last until I do something stupid like leave the headlights on and drain the battery.
Recreational Mechanic
US spec had a buzzer behind the gas gauge.
Yours may have been added as a requirement for importing a euro model as a seatbelt buzzer is a US federal requirement. I unplugged mine years ago. Only consequence on a US model is the seatbelt light will no longer Illuminate with the relay unplugged.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
Eva
Yep. I think mine is a Union Member...works when it wants to....
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
On some of the later cars (86-on I think) the seatbelt buzzer was tied to the interior lights wiring so that if you disconnected it or it stopped working your interior dome lights would no longer function.
Recreational User
On both of my '86's and my '88, the dome lights function without the buzzer relay.
