1976 911S Targa
What is torque for caliper bolts?
I'd like to know the torque setting for front and rear calipers: 1976 911S. Thanks
1976 911S Targa
Okay. Where can I find the torque specifications?
On a 986/996 it is 63 ft/lb. That should get you in the game.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
1976 911S Targa
Many thanks.
Not sure if your '77 will be the same as my '87
Front 52lbs Rear 43lbs Hope that helps.
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
Pelican Technical Article: 911 Caliper Rebuild 80lbs for a '83 SC
Googled this, http://www.torkspec.com/torkspecmm.aspx?KI=458
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew Last edited by theclaw; 12-31-2013 at 10:12 PM.. |
I'm not claiming to be an expert, but that 80lbs seems way high to me! Bentley manual is where I came up with 52lbs on the front and 43lbs on the rear. Maybe the SC has different settings though. I think I'd try and find the actual settings for a '77
My bad, that was a typo, its, 70 ft/lb. the 77 uses the same caliper as an '83
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
rear 60nm for the M12x1.5 bolts
Bill, are you sure its, nm and not ft/lb? Bob's article on Pelican quotes ft/lb
70nm = 51.6 ft-lbs 60nm = 44.3 ft-lbs
Maybe there's a discrepancy in Bob Tindel's article. He's got, " Remount the calipers on the car. Check the piston angle one more time. (Figure 15) Torque the caliper mounting bolts to 70 ft/lbs."
Can't argue with the spec book.
