CamB's Avatar
(Curtisaa)
In another thread Curtisaa wrote:
"Rob, once you rid yourself of the front bumper and the shock it's basically a early car. Yes, you'll need early fenders but the long hood will lay flat w/o the locking hardware. Just attach the the RS front rubber latches."
Sooo, to help me get this clear. If you have a 74-89 body, and you get pre-74 fenders, hood and bumpers (fibreglass or steel), then you can make an early car?
In other words, it isn't vital to swap the trunk latch panel (which was what I previously thought) - you just use the rubber latches.
What about the back of the car - just the licence panel etc to replace the reflector???
Cam
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 07-24-2002, 02:28 PM
CamB's Avatar
Geeez, lack of concentration - sorry about the 1/2 finished title.
1975 911S (in bits)
Old 07-24-2002, 02:29 PM
robh
Guest
Posts: n/a
That's a good point...What about the rear end of the car? I imagine it's easier to convert than the front.
Is anyone in the midst of a long hood conversion? It sounds pretty straightforward, but pictures are always fun to drool over...I mean, examine.
It was kind of an idle question I asked on the '73 RS thread, but now I'm more interested, and happy to see others are too.
Old 07-24-2002, 03:00 PM
74911s's Avatar
on the back of the car all you do is remove the reflector and drill out the spot welds that hold in the metal bracket between the rear lights and mount a fiberglass early rear bumper. it might be more difficult if you want to use original rear bumper parts, i do not know about this.
the whole job is really quite simple as long as you do not want the front hood to utilize the factory latch.
i am collecting that parts right now to turn my 77 into a 73 rs clone on the outside.
Jim
R Gruppe Member once upon a time when you could run generators in Cambria to fix the cars and hit 150+ mph on the fun run
"Alles ist gut" 2011 997 GTS
"Orange Pepper Wagon" 2009 Cayenne GTS
Old 07-24-2002, 04:00 PM
Administrator
Jack Olsen's Avatar
The Long Hood Brotherhood begins to chip away at the SCWDP.
Old 07-24-2002, 04:51 PM
racemor's Avatar
As they say, "long hoods are good"!
Tom
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 07-24-2002, 04:56 PM
74911s's Avatar
yeah, and my 77 long hood imposter being galvanized should last forever!!!
muha ha
Jim
Old 07-24-2002, 05:14 PM
Crusty Conservative
silverc4s's Avatar
What's next...
I can see it now, bogus long hood early S cars all over eBay......aaaaarrrrgggghhhh
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 07-24-2002, 06:29 PM
CamB's Avatar
Yeah, that was why I asked - I don't need to do it (2 cars already), but if I ever build up a car to replace the '69 the temptation to start with a galvanised car is strong.
Pity the '75 (which is and will remain short hood) isn't galvanised either...
1975 911S (in bits)
Old 07-24-2002, 06:31 PM
Crusty Conservative
silverc4s's Avatar
Clarification...
Not from anyone here, of course. Sorry if that came across the wrong way. No intent to do that...
Bill
Old 07-24-2002, 06:55 PM
robh
Guest
Posts: n/a
Oh no, anyone here would go straight to an RS clone!
Old 07-24-2002, 07:03 PM
curtisaa's Avatar
Camb, and Robh....
OK..guys, this is how ya'd do it... If you remove all the front gooddies from a post 73-88) car, like the hood, bumpers and shocks( you'll need to cut these off with a welder), and 2 front fenders...then you take off the rear bumpers ( and shocks [ by welder]) you will end up with a early car. The rear hood(motor) will latch because it's part of the body, no problem. The front will require 2 early front fenders, and 2 Left and right, turn signal assemblys, and then you'll need a front RS valence assembly, it WILL all fit. Ahh, you say... get yourself a very good "body man". If he has a laborer, doing the work give him a tip ( at least $100.00) and tell the assembler you want the gaps perfect. This sounds pretentious, but it's very important. You will not need the latch for the front hood. Get a set of RS rubber hood latches, and you'll be good. I've had my car over 140MPH and no problem.
This is a good starting point...if you would like call me:
800-888-7287..
Please consider this: you will need to Paint all parts prior to re-assembly.
Old 07-24-2002, 10:09 PM
Buy them, sell them
Adam's Avatar
What a stunning looking car! Have you got any more pics, Curtis?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 07-25-2002, 02:42 AM
robh
Guest
Posts: n/a
When you say the shocks, do you mean the ones for the impact bumper?
Old 07-25-2002, 06:26 AM
curtisaa's Avatar
Shocks...
Robh..yes that's correct. When they are cut off ( or disassembled) the front of your shorthood will appear as a early car, ( assuming you've taken off the front fenders and valence). The only thing that will appear a bit strange will the "shorthood" locking mechanism which is attached to the body. You can take apart the ghardware that attaches to the body and leave the plastic molding for appearance sake. Once you've attached the 2 new fenders( from a early car) and the turn signal assemblys then you'll be able to proceed with your RS ( or one of your choice) to install the valence. ...KEEP IN MIND, that if you're going to do 3.6, you'll want to make the necessary preps for an additional oil cooler and those options are numerous. It will be necessary to do a bit of creative design to do this, but it's not difficult. Sherwood Lee, is a very good source for these mods.... Let me know if need more inspiration !!!
thanks Adam for the kudos...
Old 07-25-2002, 09:20 AM
robh
Guest
Posts: n/a
Oh, I have lots of inspiration, I just need a 911...
Old 07-25-2002, 10:04 AM
Of course, Curtis failed to mention the final step in the conversion process: shred SCWDP membership card. -- Curt
Old 07-25-2002, 10:33 AM
curtisaa's Avatar
Yep, Curt that's true....
..but then he can submit a application for the Rgruppe......
Old 07-25-2002, 12:45 PM
