Male Trinary Safety Switch For Electric Fans - A/C Pressure Switch Trinary switch, same firm. |
The worse case condition for the system is idling. At idling the deck lid condenser see's less air movement. So, the smarter preference is to check the pressures and adjust them for "idle", not at 2000 rpms. The 2000 rpms is a 'check'. Designing or charging a system that can maintain low high side pressures will extend the life of the compressor. Quote:
2 common ways residual air or moisture remain in a system are the method or procedure used for evacuation or failure to purge the refrigerant charge line prior to charging (swapping cans is a common point where air gets into the charge line). Quote:
Not so much so with our cars having a condensor hanging over a HOT engine. Start with a COLD engine? Otherwise 2000 RPM/no load sounds like a good idea, keep the condensor closer to the OAT reference. |
Gee Wwest, you gotta be be bored to be up so early quoting in quotes.
Me? I'm just passing time while a program tries to resurrect a corrupted VM file. But, to answer you: Vent temps have stayed satisfactory throughout. What means this..? It means he's happy with what he got. "The worse case condition for the system is idling. At idling the deck lid condenser see's less air movement. So, the smarter preference is to check the pressures and adjust them for "idle", not at 2000 rpms. The 2000 rpms is a 'check'. Designing or charging a system that can maintain low high side pressures will extend the life of the compressor." A bit of a conundrum...*** 'conundrum' = There is no riddle or pun. "It was/is my understanding that when using the OAT (=outside air temp) and low side pressure to determine (re)charge level the engine RPM must be elevated, and there must be "free-flow" through the evaporator. In other words enough HOT airflow to consume ALL of the system's cooling capacity. I also seem to remember that should the compressor cycle off then the references are not valid." Simply using a low side pressure reading will not tell you the level of charge because you could have a very cold core temperature, blockage in the TEV (moisture typically) or other "stuff" going on. Raising the rpm has always been a standard procedure in Porsche's procedure and some other mfg's, however its a check. Systems are always check with the engine running, windows closed, AC on, and preferably no outside air mix (mute point because these models are recirculate only), and its common sense you don't take readings when the clutch is not engaged; at idle is the gold standard for worse case conditions, such as sitting in traffic. Here is a very good basic reference source Snap-On, Technical Training Systems, Basic Service Training Series, Book ACT279B or later editions, or, Mobile Air Conditioning Society (MACS), SAE International, Automotive Air Conditioning Refrigerant Service Guide or their Automobile Air Conditioning System Theory, Diagnosis and Service Procedures book or later editions; MACS use to produce videos as well. |
Nice post Brad!
I went for the"Ice Man Project" some years ago --- pulled all the lines and put the "ice man" hoses in and the additional condensor in the driver's rear wheel well. ... never did get to the 33 degree temps that were promoted. I'm going to revisit my system based on your post! |
| All times are GMT -8. The time now is 01:28 AM. |
