How to fit a 911 Gearbox to a 912 Stub Axle ?
Hi,
Does anyone have the definite answer of: What is the best combination of Output shafts, C.V's and Driveshafts in order to fit a '70,'71 911 Dogleg Gearbox to a '68 912 stub axle ? With all the early Hotrods out there, someone must know ![]() Any advice or info would be greatly appreciated. Cheers Chris |
Ask Eric at PMB Performance.
He seems to know which CV goes with which axle etc. Rich |
#147 of 2096
Hi Jury,
I am doing the opposite. 901 trans in a 72. Please, let us know what you did. Thanks. |
Senior Advisor
whatever the spline in the gearbox or the flange, that is what you match, (XX spline for both, etc)
08 Cayenne Turbo |
Gas Huffer
Thanks Haycait! I am purchasing a 915 trans w/ mech speedo soon and look to install it into my '67 912.
Thanks for the drawing Jury! That really expalins the combo of the whole thing.
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi 69 Porsche 911T - Project 04 Ford F-150 FX4 - Boris |
I would rather be driving
The other option is to swap the 108mm 4bolt/2 pin stub axle into the hub. this will match the type 911 transmission and give you larger CVs and stronger axle.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Agree, but I think ( again think, I am no expert ) the problem is that the 108mm Stub axle will foul against the Handbrake guide on the early trailing arm. Also the larger diametre Driveshaft is longer. Some other Driveshaft options: SWAY-A-WAY - axles, torsion bars, and shocks for trucks, cars, and off-road vehicles - Axles and Race Ready > Sway A Way Irs Axles Cheers Chris |
