-   -   "Back-grading" from Pertronix to to Points. (http://forums.pelicanparts.com/porsche-911-technical-forum/755508-back-grading-pertronix-points.html)
rennch 06-11-2013 11:02 PM
Having some ignition issues, and here's what my tech had to say:
Ignition system:
Checked ignition system and found the following:
- MSD 6AL ignition unit has been installed.
- Power and ground wire connections are too small (insufficient current)
- Should have red B+ hooked up to the starter B+ terminal. B- needs to go to a chassis ground using consistent gauge wire.
- Distributer is a small diameter 2.4/2.7L unit with points conversion (Pertronics)
- This conversion is not timed correctly and is firing the ignition between ignition cap posts causing a cross fire.
- This could be caused by the Pertronics or the non stock distributer drive gear.
- The distributer should go back to points to see if the timing issue is resolved. If this corrects the problem, the distributer should be converted to a Crane ignition XR700-0292 system.
- Also – the coil primary wires and the distributer signal wires are zip tied together in the same bunch. This can cause signal interference and should be corrected.
I have a spare points set that he gave me to test, but I just need to make sure I install it correctly. I've never installed points before, as I've always had pertronix. Any thoughts/suggestions/tips?
timmy2 06-11-2013 11:58 PM
Post a picture of the distributor wires and the primary wires your mechanic referenced.
Also some pics of how the MSD is wired up.
'79 3.0 engine with a 2.7 distributor.
Get the right electronic distributor and do it right!
James Brown 06-12-2013 12:01 AM
you need a set of points and the little screws that come with them. Leave the adjustment side a little loose, pick a lobe that is at the highest point (points open the most) and adjust to .3mm with a feeler gauge, tighten it down and your done. Dwell angle if you have one of them fancy meters is 38+- 3˚ and thats it
James Brown 06-12-2013 12:03 AM
Points are used as a trigger in place of the pretronics. but thy do have to be set correctly. good part is the points don't get burnt and should last a long time.
rennch 06-12-2013 01:11 AM
Good advice. I don't have a Dwell meter, but I can track down a feeler gauge.
Reiver 06-12-2013 07:59 AM
With an MSD in place you don't need a dwell meter...just set the proper gap.
304065 06-12-2013 09:10 AM
Ok.
Do the wires out of the MSD connect to different wires in the harness? In that case they may actually be too small
You certainly can do this, but there are other places to tap into +12v unswitched in the engine compartment
This is true, it needs to go to the chassis. Remove the paint, drill a small hole and use a short self-tapping screw to hold the wire to the frame. When you want to win the Manhattan Trophy you can weld up the hole.
What is your technician saying-- that the timing is set incorrectly, or that the magnet wheel that attaches to the distributor shaft is improperly set, or that the magnets have shifted? An explanation of HOW this conclusion was reached would be helpful.
Ok, there are only two diameters of distributor shaft, 2,0-2,2 and everything that came later. If he is suggesting that there is backlash on the drive gear, that is unrelated to the ignition trigger. Did he pull the distributor to examine the gear?
Before converting back why not answer the above? And why not borrow a 2,7 distributor to check with so you don't have to tear your presumed working setup apart for diagnosis purposes?
Now he's suggesting you use an optical trigger instead of a hall-effect, which is not without its disadvantages, not the least of which is the occlusion of the IR window in the trigger. And the whole system is not required, just the optical trigger portion, as you already have MSD.
OK, fair enough.
Remove Pertronix unit, using the same screw that held it to the base plate, install the points following the guidance in the manual. Install rubber insulator block that passes through distributor body-- the Pertronix install would have removed that. Set gap with feeler gauge, don't forget to clean and lube distributor while you are in there. Check dwell with dwell meter, even though points trigger on the rising edge you can still screw up if the dwell periods overlap.
T77911S 06-12-2013 10:25 AM
swap the wires going to the dist. IE, connect the violet to ground/shield and the green to hot/center conductor.
rennch 06-12-2013 10:28 AM
Out of Phase Rotor Pics
Here's the rotor out of phase at TDC
http://forums.pelicanparts.com/uploa...1371058088.jpg
http://forums.pelicanparts.com/uploa...1371058097.jpg
rennch 06-12-2013 10:29 AM
I don't understand this...what will this do?
304065 06-12-2013 10:31 AM
Michael, why wouldn't you turn the crankshaft to Z1 on compression TDC, turn the distributor body until the rotor points at the radial notch in the distributor body, tighten the clamp a bit, start the engine and set your idle timing by further rotating the housing, then tighten the clamp down?
Am I missing something here? Did the poster above nail it, do you have a counterclockwise distributor gear installed, and you are trying to use a clockwise distributor? You must change the distributor gear if you want to use the earlier distributor. It's easy enough to check, remove the cap and turn the engine over carefully by hand and see which way it turns. If it turns CCW then you need to source an SC distributor.
T77911S 06-12-2013 10:43 AM
the MSD is looking for a neg to pos signal. yours may be pos to neg and if so, the front edge is not very "clean" and that makes it fire between cap posts. if you look at your timing at idle, it is probably VERY advanced, like 30-50 degrees.
look me up and find the thread i started about MSD and timing, but here is how i figured it out:
i was/am having a miss issue on my 930. so i looked at the dist output to the CD unit. (CCW rotation). the signal was clean from pos to neg but on the front side ramp up to the pos peak, the rise time was not very steep and and some oscilations on it. i put in an MSD to eliminate my speed relay but the car ran like crap. in short, i found the timing VERY advanced even though i touched nothing else. i started to rotate my dist to fix it then i said no, something is not right. so i researched and found MSD wants a neg to pos signal. i swapped the violet and green and it fired right up.
i dont know what the pertronix signal looks like or your rotation, but i would swap the 2 wires.
with that said. i prefer the reliabilty of the points.
i think this is only a real issue with CCW porsche distributors. as for yours, not sure.
rennch 06-12-2013 10:53 AM
That seems pretty easy to test. If it's NOT that, can this do any damage?
T77911S 06-12-2013 10:59 AM
i was going to do that on my 930 but you cant.
this is very confusing to explain.
imagine a line drawn at about an 80 degree angle, from left to right, top to bottom. the left side is the front/begining and it is positive(POS). the top right is negative(NEG). the center is 0volts or ground.
then the signal goes back up to the POS side of the next pulsse to fire the next plug. BUT, in between the signal is not a straight line and can look kinda "funky", like maybe an "S".
the bosch CD uses the staight line where it crosses from POS to NEG, or about.
the MSD is looking for the point where the signal crosses 0volts in a NEG to POS direction. unfortunatley this point is the "funky" "S" part of the signal. this part can also be very inconsistant and make the timing jump around.
so simply swapping the 2 wires now makes the signal "appear" to go NEG to POS.
its like connecting a multimeter up to a battery backwords. its still 12.6 volts, now it just reads -12.6v
i hope i did not make it worse. its hard for me to explain typing.
T77911S 06-12-2013 11:05 AM
here is something from some info i have on MSD.
notice what i have in bold. it says it will fire early, which = advanced timing. it will also advance even more as the RPM's go up.
The magnetic pickup inputs are the violet and green wires. The green wire is grounded internally to the unit. My unit fired when the voltage on the violet wire reached about +0.3 V, and it triggered on the rising edge of the signal. This is important information, as it will affect the timing depending on the polarity of the signal from the magnetic pickup. In the correct case: as the rotor in the distributor approaches the
magnetic pickup, the voltage will go negative to some max value, then swing positive. It will pass through 0V as the rotor is exactly lined up with the pickup (this is where you want the ignition to fire); the voltage will continue to go positive to some max value, and then return to 0V as the rotor rotates away from the pickup. It is the negative to positive transition that you want as the trigger reference. If the wires are reversed so that the signal goes positive first, the unit will trigger early (as the rotor approaches the pickup). This will cause early timing. Even worse, the trigger point will change depending on RPM, as higher RPM will create higher voltages. This is illustrated in Figure 1.
rennch 06-12-2013 11:16 AM
Here's my wiring diagram...which ones should I swap?
http://forums.pelicanparts.com/uploa...1371060899.jpg
Also, my guy had this to say about swapping the wires: "That doesn’t apply to your car.
That applies to a late distributer with magnetic pick up. Just replace the points and tell me if rotor position improves."
I'm way out of my area of expertise here, so I'm fumbling a bit.
304065 06-12-2013 11:22 AM
You don't use the magnetic pickup wires with MSD and Pertronix, you use the white points wire.
Click this link for diagram: http://www.pertronix.com/support/tips/pdf/msd6series.pdf
T77911S 06-12-2013 11:24 AM
If you still have points, you only have one wire.
i was trying to help with your pertronix setup.
if you have the points back on and i take it the timing is very advanced at idle, then that is a mechanical issue with the distributor. either the points are mounted wrong, the plate is wrong or the advance springs are not connected and it is at full advance at idle.
rennch 06-12-2013 11:26 AM
No...I currently have a brand new Pertronix II ignition installed. It's wired exactly like the diagram I posted above, with the MSD Tach adapter.
T77911S 06-12-2013 11:50 AM
i will have to look into the pertronix hookup some more, i thought it used the magnetic hookup, not the points hookup.
what is your timing at idle?
it may come down to what 304065 said, rotate the dist shaft so you can adjust the timing. thats the problem i had. it was so far advanced, i could not retard it enough to come close to the proper timing, and like yours, mine was sitting between to posts
i would stay with points, but thats me. i like reliability.
rennch 06-12-2013 12:02 PM
Well, I will definitely swap the points for the Pertronix, as recommended by my guy. (Who, by the way, has a stellar reputation as one of the "guru's" in the SoCal area. )
It just seems like I've got to grab a feeler gauge, and I should be all set to do the swap.
304065 06-12-2013 02:44 PM
Michael,
You didn't answer about the distributor drive gear. If you or a prior owner didn't change the drive gear, then the distributor will spin backwards, and instead of advancing when the flyweights move out as speed rises, it will retard. Obviously this is not good.
rennch 06-12-2013 02:47 PM
I can't remember off the top of my head. I want to say it's clockwise. I'll check when I get home.
T77911S 06-13-2013 04:50 AM
sorry, my wastegate for my 930 came in and i was messing with that.
if it is rotating backwords, i dont know what effect it would have on this system. it may work fine, but as mentioned above, you would not have any advance, but idle would be fine.
electrically it may or may not effect it. call pertronix.
if your timiing at idle is way off, which would look like it is firing between posts, that could also be something mechanical. is everything mounted properly? are the springs on the mechanical advance still good?
also check the grounds. i am guessing the pretronix gets its ground through the dist body. the plate that it mounts on needs to be grounded to the body.
were/are the vacuum pots still being used?
rennch 06-16-2013 12:29 PM
guys...quick question. I have a black and a red wire coming out of the pertronix. I'm about to do this swap. Looks like I connect the white wire to the points once I install them. Where do I connect the red wire coming out of the MSD?
rennch 06-16-2013 12:31 PM
http://forums.pelicanparts.com/uploa...1371411047.jpg
Looks like I'm meant to connect to a switched positive. Anywhere in particular you guys like for that?
T77911S 06-16-2013 04:02 PM
the diagram in post 16 was better.
the red wire goes to switched power AND to the red wire to the pertronix. the white mad wire goes to the black pertronix wire.
someone asked about rotation direction, i wonder if that still matters with the pertronix.
you should call them and talk to them about it.
did you ever check timing at idle?
rennch 06-16-2013 05:36 PM
Once again...I am de-installing pertronix in favor of points, to test something.
However, here's my current problem. And I'd love to get someone on the phone that knows of these things.
My distributor is out, and I didn't think to mark TDC before I did that. I now have the upper left valve cover off, but I'm having a hard time distinguishing a "loose" valve from a tight valve. Can anyone help?
James Brown 06-16-2013 05:38 PM
to find tdc#1 take the #1 plug out and using a hose in the plug hole, turn till you hear/feel air coming out and stop turning when you get to TDC mark
rennch 06-16-2013 05:47 PM
I can't manually turn the motor at all, so I'm having to use the ignition in short bursts to rotate the engine.
I have the upper valve cover off at the moment.
Any other suggestions?
James Brown 06-16-2013 05:54 PM
you can still do it that way with short pops of the starter. to get right on, use 4th gear and move the car till the TDC lines up.
rennch 06-16-2013 06:02 PM
As long as my pulley notch is vertical, can't I rotate it til it's at TDC, install the distributor, and if it doesn't run, rotate it one more time? Is it 1 full rotation per 2 cylinders firing? OR am I off?
fastfredracing 06-16-2013 06:26 PM
I like to take my switched positive right off the connector that went to the original CD unit. I always grab my 12v battery, off the large starter post. I do however, have one in the shop now that is taking 12 v battery off the little fuse panel in the back, ( not my work ). and it seems to work perfectly .
James Brown 06-16-2013 06:27 PM
dissy moves at 1/2 speed so 1 complete rotations for every 2 engine rotations. please do it the right way and don't confuse yourself (and me) by trying to re inventing the wheel. IT HAS to be at #1 TDC before preceding any further. whatever it takes to be 100% sure it is is what it takes.
I went with the starter connection for a positive direct connection to the battery
rennch 06-16-2013 07:21 PM
Am re-assembled with what I thought was TDC. Doesnt fire...then one huge giant "poof" of a backfire.
Giving up for the day
T77911S 06-17-2013 07:13 AM
its usually 180 out when you get the big bang. check firing order.
dissable the fuelpump and crank it while checking timing. from your original post where you said it was between posts onthe cap sounde like your timing is VERY advanced.
jpnovak 06-17-2013 08:09 AM
Michael,
Don't you have a 3.0 in the 69? I remember you swapped it from another car. however, that is not a 3.0 distributor in the picture. its too small diameter and would certainly not have the points plate in it as it used a variable reluctor wheel and coil wire. Even if you have a different distributor with a swapped crank gear the advance mechanism would rotate the wrong direction and give you a very strange timing curve. What is the part number on the distributor and what is the type number of your engine?
It is difficult to troubleshoot based on your descriptions. here is my method for aligning either a pertronix or Crane system. ( I personally prefer the Crane as I have seen too many burned out pertronix over the years where the car is left with the ignition on and the hall sensor overheats from too much current. I digress)
1. Put motor at #1 TDC. Use Crank pulley and loose valves on #1 to verify. The #1 valve will be loose (valve adjustment gap, slight tick) on TDC. It will be tight (overlap) when 180 deg out.
2. pull distributor and align the rotor to #1 tick mark on body. If a CCW distributor from a 3.0 The leading edge of the rotor would point to the tick mark.
3. Slide pickup onto the distributor shaft. The pickup is the magnetic sleeve on a pertronix or the shutter wheel on a Crane. It has some rotation on the shaft for phasing.
4. Turn on ignition and clip timing light (or use spare spark plug) to #1 cylinder to check for spark.
5. Hold rotor still and rotate shaft pickup until the engine fire. You are now phased correctly. Remember, the distributor shaft is locked to the crank via the crank gear. The distributor body slides independently and now the pickup can rotate on the shaft. You must have alignment and phasing between all three before anything will work properly.
6. Hold rotor and rotate back shaft pickup. fine tune to the point where the ignition will spark when you rotate the rotor against its mechanical advance.
7. The engine should now start (assuming everything else on the motor is working).
8. Use timing light to fine tune timing to spec.
If the system does spark but the timing is off you need to phase the ignition pickup./
brads911sc 06-17-2013 08:18 AM
what is your rationale for not running the correct distributor?
rennch 06-17-2013 10:17 AM
No rationale...it's what came on the motor I bought.
At the moment, I have points in, and am just trying to get the car to fire. I think I might have it 180 degrees out of phase though.
brads911sc 06-17-2013 11:03 AM
I see. Hopefully you can get it sorted...
If it were me Id try to source a used one and have Berry Hershon rebuild it and give it Mechanical Advance. This had the biggest impact on performance of anything I did...
