-   -   Electrical problem - tail light cluster (http://forums.pelicanparts.com/porsche-911-technical-forum/755540-electrical-problem-tail-light-cluster.html)
gjmascoli 06-12-2013 05:49 AM
Rebuilding the left tail light cluster. The PO tore up left turn signal bulb socket and I just repaired it and replaced the backplate at the bottom of that socket that the bulb makes contact with to complete that circuit.
Anyhow, prior to repairing the bad socket, I had the lights working (parking, brake, reverse, etc). Only the turn signal was not working.
Now, when I switch on the lights with key in ignition turned to "2" position, all the lights in the cluster are on simultaneously. Any ideas? I haven't yet scrubbed all the fuses.
Btw, this '76 911S has sat idle for 13 years.
Otto H. Wegkamp 06-12-2013 03:01 PM
If all the light are on, but less bright, than a ground problem might be the cause. You have repaired the turn signal socket. Could it be that you forgot the ground wire or could the ground wire be broken?
Otto
gjmascoli 06-17-2013 04:36 AM
Took the right side apart yesterday to get the correct connections. Found my error. Everything woking perfectly now!
One step closer to the road!
